billwill wrote:I have seen it mentioned a few times on this forum, so I think it is quite a common modification to fit the bigger +2 brakes on the front of a 2-seater Elan.
On a single master system maybe, but unusual on a split system.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Hi Ted
I just went through a similar scenario bleeding my clutch and was finally able to get it using a mityvac vacuum pump while constantly keeping the master cylinder full. Once the fluid gets rolling it eventually pulls the air along for the ride. The trick is to get the bleeder closed while the fluid is still moving. Your method of using the clear tube to spin it closed seems like a good idea to me. I was able to do it with my skinny fingers but the car was on a lift and I had two helpers. Good Luck!
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
A recent thread on +2 brakes in a two-seater is here (somehow posted in the Cars for Sale forum):
lotuselan-for-sale-f2/brake-pedal-travel-t37474.html
Includes a discussion of bleeding, and how to detect and cure pad retraction. The bad news is that you may have to remove the calipers, take out the pistons and reassemble with suitable grease to fix retraction.
BTW, I have been able to blow out stuck pistons with a bicycle pump, which can deliver 130 psi or more. Just be sure your fingers and eyes are no where near the caliper when the piston comes out.
Best of luck with the trip to Princeton!
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
Looking forward to seeing your Sprint at LOG36 Ted!
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
It's on the trailer and on our way to LOG this morning!!!!
Actually I took it for some miles yesterday and am quickly gaining more and more confidence in its condition and road readiness. I actually took it out on the interstate highway up to 70MPH and it didn't miss a beat! My air horns are now working too!
My list of "things to do" is getting longer. I have yet to:
* Change oil, filter, flush coolant, replace points and/or install Petronix point-less, bleed brakes, rebuild carbs, compound/wax, finish vacuum lines, install headlight pod links, install the wiper blades, and a dozen other little odds & ends.
THANKS EVERYONE FOR YOUR COMMENTS, HELP, SUPPORT, AND SUGGESTIONS. I may have not responded to each one, however I read each one and have gleaned the tid-bits suggested here and there. Without your help and input, I would have not gotten it finished.
TED
- tedtaylor
Way to go Ted! See you at LOG36!
Glen
just FYI for everyone following this thread.
the Sprint DID make it to LOG!!!
thanks again for your encouragement, help and support!
TED
- tedtaylor
Great to see you & your Elan at LOG Ted!
Here's your & my car in a sea of Lotii:
Your car has a number of original features that are not often seen. For example, Look at the profile of the clear window in the back of the hood, note the bottom edge is parellel to the bottom edge of the vinyl - not straight across.
Phil Harrison
Ted showed me his original Sprint in great detail after the Concours and I agree with him that it should be kept in its original condition and not restored. Get the mechanicals all working properly and drive it. Great car Ted!
Glen
