Wing mirrors
As you know i've just finished restoring my S2 Elan and am in the process of choosing the wing mirrors.
I would like to know if anyone has gone down the route of putting some clamp-on wing morrors and fixing them to the window frame upright ?
I don't really want to drill unecessary holes in the bodywork unless I really have to.
Gino
Milano
Italy
Gino
Milano
Italy
1964 Elan S2 Roadster
1965 Elan S2 Roadster
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
Evening Gino,
I have the same thoughts as I don't want to drill holes in my car's bodywork (when I finally get to that point)
To be honest, I just don't think mirrors look good on an Elan but at least clamp-on type mirrors would be the least damaging!
- S3FHC
Hi Gino - there is a picture of a yellow Elan with a wing mirror on the window frame in my post here:
lotus-talk-f50/new-year-day-2016-brooklands-t36347.html
Not sure of the type of mirror you're thinking of, but thought I'd pass along this example.
Rich
Rich
"What kind of a man are you? Don't you even like dolphins!?" - Zorba the Greek
69 Elan S4/SE DHC
66 Ford Mustang Conv. (289ci)
71 Cadillac Eldorado Conv. (8.2L)
65 Buick Wildcat Conv. (425ci)
And a pickup truck full of Miatas....
69 Elan S4/SE DHC
- SF69Elan
I have the clamp on mirrors on both sides of my S2. I think they look and work fine. Will try and find a pic if You really want to see
1965 Elan S2 (26/4726)
2002 Elise S2 (now sold )
1970 Scimitar GTE
1970 Scimitar GTE
- Geoffers71
Thanks for the pictures Rich they look the type i'm after.
Geoff if you could post a picture of your S2 mirrors ?
Gino
Gino
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
Just a little word of warning, my friends series 3 has had a clamp on mirror fitted at some time & it has left nasty marks & dents in the window frame which have proved impossible to completely remove. It's quite unsightly & the only way we can think of to hide them, is to fit another mirror, which he doesn't really want.
If you go for them, be careful when tightening them up ! I'll try to get a photo today & post it later.
- Orsom Weels
Photos as requested
I take the point about being aware of the possible damage to the frame, but I used a sliver of hard plastic between the screws and the frame which seems to avoid any damage. I found that I had to cut out a thin slice of the weather strip inside the frame, just where the mirror bracket fits, so that the window is not made any harder to slide.
1970 Scimitar GTE
1970 Scimitar GTE
- Geoffers71
here a whole selection.....rectangles, circles.....etc etc
http://www.holden.co.uk/displayProducts ... on+Mirrors
I have one for my Sprint which I am unable to fit as it's just too tight between the outside of the window glass and the inside of the frame.
I haven't had the nerve to start cutting away weather shield felt.
'72 Sprint
'72 Sprint
- richardcox_lotus
Thanks to all of you.
Your suggestions on this matter have now helped me understand what I need to do.
Gino
Milano
Italy
Gino
Milano
Italy
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
I have noticed markings on the frame from the set screws on a friends car. I think I would try to slide a thin piece of aluminum or brass between the screws and the frame. This would prevent the screws from marking the frame and should allow sufficient clamping force to keep the mirror in place.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Hopefully the pics will show the damage to my friends window frame, it actually looks a lot worse in real life. We don't know what sort of gorilla tightened it up originally, but an example of the damage that can be easily done, but not so easy to rectify.
- Orsom Weels
wow..that looks like some serious damage which will be difficult to remove.
Gino
Gino
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
I have a clamp on mirror in fact it is pictured on the link from an earlier post to the Brooklands New Year gathering - mine is the yellow 69 SE
I bought the mirror from Classic Car Accessories and it is the CME190 'Overtaker clamp on oblong'.
I have attached a photo and you will note that this comes with both a rubber pad and a stainless steel 'spreader' plate so there is absolutely no damage caused to the door frame.
A couple of cautions in that the quality of the mirror is not brilliant and there are signs of the silvering breaking down around the edge and also they do need clamping on tight and I found that the Allen headed screws provided are not man enough for the job so I replaced them with better quality set screws. I also had to bend the brackets to get the right viewing angle
Hope that helps
Hope that helps
1969 Elan S4 SE
1969 Elan S4 SE
- HampshireMush
Users browsing this forum: No registered users and 54 guests
