Send me some of that passion, .......please! Great start! Tell us your plans and good luck!
Frank
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
The plan is to keep it a road car and to stay true to the spirit of the Elan. It will always be a vintage vehicle and need fettling but efforts will be made to make it a little more reliable. Keeping the cv rear axel, electronic ignition, modern alternator, one piece exhaust manifold etc. Every nut and bolt will be gone through.
The motor will get a few more HP but nothing radical. Blue printed and balanced. A cam to open up the strombergs a bit.
Paint will be lotus themed but possibly not correct for the year. Same with interior.
26r headlight just because I personally don't care for the look of the pop ups.
Here's an update photo.
Kevin
1969 Lotus Elan S4 DHC
John Player Special
One of none
John Player Special
One of none
- Mister E
Famous Frank wrote:Send me some of that passion, .......please! Great start! Tell us your plans and good luck!
Frank
Thanks Frank. Starting wasn't so scary. Let's see how long the momentum lasts.
Kevin
John Player Special
One of none
John Player Special
One of none
- Mister E
Restoring is all about momentum. Make yourself a list of things to get done in certain periods of time. You will be amazed at how much you will accomplish. Or not and then it might take years......... Many restoration projects get sold almost near completion because they took so long the energy and excitement is gone.
I'm a bit of a fanatic and work diligently to get projects done in short periods of time (weeks instead of months or years).
The biggest issue is parts availability and cost. Both get in the way and slow things down.
Good Luck and remember, have fun!
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
...and someone (you in the past?) has already done the frame stiffening mods. You're a step ahead to start.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:...and someone (you in the past?) has already done the frame stiffening mods. You're a step ahead to start.
The frame had no stiffening done prior. We also did the stiffening at the uprights. We are doing the all the critical spots as outlined on this forum. Powder coating the frame will be next step.
Kevin
John Player Special
One of none
John Player Special
One of none
- Mister E
Duh, that's the step you're doing now. From the pic I thought you were just cleaning up. Should have seen the obvious ground lead for the welder laying there. Looking good.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Another inch forward. Body to painter. Absolute top notch shop that has fiberglass skills. Unfortunately in Portland Oregon a 4 1/2 hour drive from home.
- Attachments
Kevin
John Player Special
One of none
John Player Special
One of none
- Mister E
Although Lotus never could have made one. The first John Player livery was in '72 I believe. I would like to think the original cast of characters at the Hethel plant would approve. Progress. Powder coated frame after adding a bit of stiffening. Restored steering rack. Fiberglass repair. Tail light mod in progress (S1). Mock up of rear suspension. New solid brake lines. All new running gear, bushings and bearings.
- Attachments
Kevin
John Player Special
One of none
John Player Special
One of none
- Mister E
just as a tip I use saran wrap to hold the wet fiber glassin place till it hardens then it peels off leaving a nice smooth surface ,,works up side down too ,,ed
Users browsing this forum: Elan45 and 27 guests
