S1 Elan Rebuild - My Story
Excellent recommendation Peter. Will look closely when I disassemble and reassemble the hub. Thanks!
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Finally got all the rear suspension and differential off. Started cleaning various parts and painting. Long weekend ahead so I expect to make some progress
Glen
Great thread just watched the time lapse you two won't need to spend time at the gym you must have cover miles moving around the elan. keep up the good work.
You know you have a good car when your wife hates it.
Jon.ford - Second Gear
Spent the day removing the rest of the suspension and steering rack on the old chassis. Cleaning original parts for painting and chasing down high grade bolts/nuts/washers (#8) for the rebuild. There are a mixture of SAE and metric bolts/nuts on this car plus lots of stripped threads and worn nuts so I am constantly needing to get new SAE bolts/nuts/washers.
Started putting new parts on the new 26R chassis. Ran into a problem right away, seems the new lotocones I bought don't fit. The "ears" are too big and the bolt holes don't line up with the threaded hole on the chassis. The old ones fit perfectly. I wonder if I need to grind the metal a bit to make them fit?
Some photos from the day:
New day for parts removal on old chassis
Painting front suspension pieces
Finished removing the steering rack with front hubs attached
New differential mounts from TTR
AVO front coil overs - fast road setup
Glen
Full day again today. My friend Drew was able to help and thank goodness as the removal of the shock tubes was most difficult (it took 3 hours for both). You need a torch and a press to remove them. We moved from my shop to his to do this as he had more appropriate equipment and we needed his lathe to lap the hubs to the TTR hubshafts. The differential bearings, seals and TTR shaft replacement went without a problem. Also got the steering rack back on, the anti-roll bar and front calipers. I am replacing most of the bolts, nuts and washers with grade 8 during the rebuild.
My rebuilt engine is in the final assembly mode and being dyno tuned this week. The plan is to pick it up later in the week which means the engine and transmission will go back in this weekend.
I might actually be able to achieve my 3 week rebuild plan. The clock is ticking........
Some photos:
Some photos:
- Attachments
Last edited by Certified Lotus on Tue May 26, 2015 1:35 am, edited 1 time in total.
Glen
The photos above are out of order, but I'm too tired to fix it. Here are some more photos out of order
- Attachments
Glen
Great pics and story. Keep 'em coming. The oxy/acy torch would be more appropriate. Propane simply
isn't enough heat for the area needed to heat.
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
45/0243K Sprint
gjz30075 - Coveted Fifth Gear
You are certainly making amazing progress ! - a couple of comments
Pulling the rear wheel hub with a 3 leg pulley will often bend the hub. You may have been lucky but check it to make sure the wheel still runs true.
Your a braver man than I to hold a hub while you spin the shaft in a lathe, I would worry about my fingers if it jammed
. I lap in by hand as both safer and you get a better result with an oscillation motion with constant removal and re-seating just like lapping in a valve on its seat. Constant single direction rotation can generate grooves in the hub and on the shaft if your not careful.
Rohan, good points. The hubs came off without much force but I will check them again (they spun true on the lathe). Yes, lapping the shaft on the lathe could be problematic but it turned out fine. We were careful about grooves on the shaft.
Got my new shock tubes from TTR. I'm following the suggestions of putting the tubes in the freezer overnight and will heat up the bearing carrier in my propane outdoor grill as it will easily get to 325 degrees F. I am doubtful they will just "drop in" so I'm prepared to provide a bit of force with a block of wood and a large hammer (carefully).
Will also be careful regarding which bearing goes where as there are two different sizes for the bearing housing.
Last edited by Certified Lotus on Wed May 27, 2015 12:23 pm, edited 1 time in total.
Glen
Excellent posting above, but I was confused because I seemed to have read the above message before but with less detail
So I looked and I had...
Just a little tip: It helps the consistency of the forum if you include crosslinks when you post on the same matter in more than one topic. Well at least it helps me, to know that I'm not going potty yet.
Your other message is in:
lotus-suspension-f42/removing-rear-dampers-t34204-30.html
Thanks Bill. You are absolutely correct. Will make note of referencing crosslinks!
Glen
PS:
I've found you a chart of melting points of metal:
http://www.engineeringtoolbox.com/melti ... d_860.html
deg C DegF
Aluminum 660 1220
Aluminum Alloy 463 - 671 865 - 1240
Aluminum Bronze 600 - 655 1190 - 1215
You might want to practice on some unwanted bits of Alloy to see if you can actually melt them so that you can avoid that disaster.
As mentioned before, you get no warning. It just suddenly get a darkish skin, but by then it is too late and the alloy 'runs away' under the skin.
deg C DegF
Aluminum 660 1220
Excellent Bill! Now I know for sure I'm not even going to be close to melting the bearing carrier. I don't have a piece of unwanted bearing carrier (I assume a test is only valid using same material cast in same time period) so it will be an experiment.
My friend Drew and I where talking this weekend about heating the entire bearing carrier in the oven when we both agreed that our wives are great cooks and the potential for ruining the house ovens with oil and grease smells would not go over well. That's when I thought of using the outdoor grill.
Bearing carriers on the barbeque this weekend! Yum
Glen
billwill wrote:PS:
Magnesium alloy from 350 C
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
S4 SE
S2 GTS
Peterson JPS Exige
661 - Fourth Gear
Certified Lotus wrote:Rohan, good points. The hubs came off without much force but I will check them again (they spun true on the lathe). Yes, lapping the shaft on the lathe could be problematic but it turned out fine. We were careful about grooves on the shaft.
Block of wood and a hammer is not ideal!! Tried that way many years ago and it nearly ended in tears, If possible find some one with a decent press you can use
- seriouslylotus
