Are lotus engineers sadic perverts?
PostPost by: Pistacchio sprint 72 » Sun Oct 13, 2013 11:29 am
I decided to remove my dead gearshift gaiter and replace it by the one purchased a few month ago from Sue.
Removing was a 10 seconds job.
But putting the new one in place... Geez half an hour at least of fighting with the new piece of rubber! :mrgreen:
I admit i swore a few times...
image.jpg and
Cooled down by CliveyBoy!
PostPost by: gjz30075 » Sun Oct 13, 2013 11:35 am
The console has to be removed. The gaitor attaches to a piecs of sheet metal below the console, screwed to the fiberglass. The bottom of the gaitor has a 'lips' that fit the sheet metal like a grommet. The console then gets refitted.
My new gaitor fits very loose in the sheet metal and seems smaller because it has a hard time fitting over the anti sizzle bush, which I see you have. Let me know how Sue's fits.
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: richardcox_lotus » Sun Oct 13, 2013 11:38 am
Interesting, as I have to do mine. Does the tunnel trim have to be removed before refitment ??
'72 Sprint
PostPost by: Pistacchio sprint 72 » Sun Oct 13, 2013 11:47 am
I managed to install it without removing the tunnel.
I did not feel there was any metal sheet underneath the edges of the hole.
Sue ?s model fit very tight.
I guess i should go for a drive and tell you all if it stays in place.
PostPost by: gjz30075 » Sun Oct 13, 2013 12:40 pm
This thread lotus-gearbox-f37/anti-sizzle-stick-boot-t29199.html shows the metal plate. Ignore the pieces of wood, as that was my attemp to raise the sheet metal for that problem.
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Pistacchio sprint 72 » Sun Oct 13, 2013 2:28 pm
Well, i mounted the new rubber gaiter like the old dead one was installed. The rubber lips against the fiber glass of the tunnel. I did not see any metal plate.
PostPost by: Galwaylotus » Sun Oct 13, 2013 7:12 pm
I installed mine on the console hole. It's a bit of a pain to get it to fit but a flat blade (e.g. screwdriver) works well to get the last bit to fit correctly - like a shoehorn! 8) I do have an issue sometimes in selecting reverse in that the bottom comes loos from the console. Otherwise it fits well. I use ArmorAll to keep it from drying out.
'67 S3 SE FHC
Galwaylotus
PostPost by: AHM » Sun Oct 13, 2013 8:11 pm
As Greg says!
Sit in seat
Remove gear knob
Remove console
Attach Gaiter to metal plate
Replace console
Replace gear knob
shouldn't take more than about 5 minutes
AHM
PostPost by: elanfan1 » Sun Oct 13, 2013 9:41 pm
As above is correct.
Warning to the others - may not be a serious issue but you could be allowing exhaust gasses to enter your car through gaps in the centre console seating - there is some potential for CO poisoning which may not be a good idea whilst driving.
PostPost by: AHM » Sun Oct 13, 2013 10:06 pm
Good point about the fumes!
Relative parts are referred to in Parts and Workshop manuals as:
Tunnel Top, plate and grommet
AHM
PostPost by: sprinter55 » Wed Oct 16, 2013 11:27 pm
maybe a silly question but how do you remove the console ??
sprinter55
New-tral
PostPost by: AHM » Wed Oct 16, 2013 11:32 pm
Lift it up at the back edge, and slide backwards and up. (put in 4th gear first)
it is held in place by the pressure of the plastic sides - which may be a bit fragile.
AHM
Users browsing this forum: alan.barker, berni29, h20hamelan, snowyelan and 54 guests
