Spyder Suspension and Roll Protection Fitted
Hi all,
Picked my car up from Spyder yesterday after having all new suspension (springs, dampers, bones, bushes, rollbar) and roll over bar and side impact protection fitted. They did a really superb job. After some discussion with the guys there I decided to have everything adjustable fitted and have them set up the car. What a difference! OK, my car has had Federal springs fitted at some point in the past, and has developed a saggy bottom, so it was hardly handling its best, but I didn't quite expect the transformation it received.
I took it back home across some familiar twisty roads where I knew I could really experience the difference. Some corners where I really had to force the car to turn now aren't even noticed, it just goes as if on rails. In sharpish turns at anything over 40mph the nose used to twist a bit and feel unsettled, but now it just remains planted without any noticeable body roll at all. The damping is firmer than before, so you feel some of the smaller bumps a bit more, but the primary ride over larger undulations is so good that I won't mess with it.
The roll over bar fits really neatly into the coupe, it looks as if it was always meant to be there. The best bit though, is that the seatbelts now mount on the side rather than behind the neck, which used to drive me nuts.
On the way home, on the A1, my throttle cable snapped at the part of the motorway where there was no shoulder at all. Trying to fix it while the lorries are trying to avoid you at 60mph is not something I'd like to repeat. Bodget it enough to get me home, and luckily I have a couple of spare cables, so it's a job for tomorrow.
Adi
Adi
1967 Elan S3 S/E FHC
adigra - Third Gear
Pictures !!!! ???
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
Well, it seem like my offside rear wheel bearing is failing. I did hear an intermittent knock from the back on the way up from Spyder, but it got worse today and I could feel the rear move around a bit while manoeuvring at slow speeds. After I checked the wheel I could move it a bit and replicate the knock. At first I was worried it might be something with the new suspension parts, but it seems to be coming from the hub. Unfortunately I couldn't get the hub off without a puller so I'll have to wait until Wed to have my local tyre place pull it apart.
Am I right to assume that Spyder would've had to have the hubs and shafts apart to fit new springs, dampers and bones at the back? I suppose it must've been enough to disturb the old bearing enough to push it over the edge.
adigra - Third Gear
A couple of photos of the roll bar. It was so bright outside (amazingly!) that it was very difficult to get anything to show. Anyhow, hopefully you can see just how neatly it fits into the coupe, and from the outside it looks like it belongs. Notice the new seatbelt mountings. So much more comfortable.
Adi
Adi
adigra - Third Gear
I agree, I would've also expected the bearing to grumble before any knocks and movement, but the movement is definitely in the hub. When I took the wheel off I could still move the hub a fraction, but nothing else. Potentially the outboard shaft might be damaged instead of the bearing. I took the nut off and noticed that it was so tightly done previously that it pushed the washer into a concave shape. No joy though, the knock is still there.
I have the car booked in with a specialist, so we'll see. Sadly it's not for another two and a half weeks.
adigra - Third Gear
Have you tried refitting and torquing the hub nut, as after new bearings they can settle. Excessive end float, and the forces of the outer drive shaft moving in and out with suspension movement and cornering, might have hammered your washer concave.
Peter
Peter
PeterK - Third Gear
Did spyder took off the body to install the roll bar?
Do you know if the silent blocs (bushes)connected to the engine mount are standard items? And not specific to spyder?
