S3 SE Spec
Is there anyone in the Staffordshire, West Midlands or Derbyshire areas of the Uk owning a completely standard s3 se.?
I would like to take the car that I have recently purchased with the exception of a few updates like an alternator, high torque starter motor and spyder chassis with roll cage back to original spec. It will be on the road winter and summer hence sticking with those modifications It will be a lot easier to have a look at the vehicle than just look at pictures in books. Mine is an early FHC car without the vents in the rear Quarter panel and although it sports the se badges I'm not sure that it came out of the factory as an se model. Two things it hasn't got are the brake servo or inertia reel seat belts. It has been restored by the previous owner and when he bought it, it didn't have the twin cam engine but a 1300 ford unit.
Should the s3 have a door pull handle as mine just has the opening lever and non of the pictures in books that I've got show a complete s3 door interior? I know the later cars had mgb pull handles should the s3?
- jmp
I don't know but I would start by looking at this
http://www.lotuselan.net/publish/car_type_by_vin.shtml
July 1966 36/5977 S3 FHC SE Introduced
If your Coupe was invoiced before than I doubt that it is.
p.s. - I think you shroud refer to your Coupe as an Elan Coupe maybe with the describer of "pre-airflow". Just my opinion ya know.
Thanks for the link. It is chassis no 6037 July 66 which indicates it could be one of the early s3 'pre-airflow' cars.
Thanks for the photo I am missing those door handles. Are they like hens teeth to get hold off?
I've also not got the electric window switch in the door it is on the dash.
- jmp
jmp wrote:Thanks for the link. It is chassis no 6037 July 66 which indicates it could be one of the early s3 'pre-airflow' cars.
I think the handle is off a Hilman Imp, don't think they're particularly hard to get hold of (groan door handle), unlike the outside handle which is.
Mazzini - Coveted Fifth Gear
John,
By the sound of it, I think you are right about your car not being an SE originally as some of the features which made an SE are the belts and the servo, although they could've been removed at a later stage.
If you don't find a car closer to home, I am in West Yorkshire and have a S3 SE coupe (airflow), with a completely standard interior with all of its original instruments, trim, etc. I have newer belts fitted, but I have the rotten originals saved. I also removed the radio, but also have it saved somewhere.
Adi
Adi
1967 Elan S3 S/E FHC
adigra - Fourth Gear
Hi Adi,
Did your car come with static or inertia reel seat belts? If you read the blurb and look at the road tests from '66 and '67 S3 SE's had Teleflex inertia reel belts, the reel mechanism was contained in a large off white plastic casing which sat on the rear bulkhead. I don't think they were very effective and I've only ever seen one set still attached to a car. The attachment point for the buckle, down by the chassis, was made out of plastic and I think in time they fell apart. Teleflex may have had the patent on the design.
Cheerio,
Cheerio,
Yes, my car came with the Teleflex ones. Ugly white cases taking up a lot of room behind the seats. I would've kept them were they not completely rotten and seized. I replaced them with static belts, but still have them with the idea of making them work down the line.
My car was incredibly complete with absolutely everything original still on it. The unfortunate thing was that almost everything was rotten, mouldy or rusty after 10 years in a damp garage.
Adi
Adi
Mazzini wrote:unlike the outside handle which is
Hi Mazzini and others.
I thought the exterior handle on the S3 was from the Austin/Morris 1100/1300 range of cars. These used to be a dime a dozen over here in New Zealand, markedly more common than the Hillman Imp. If I recall correctly from Brian Bucklands book, Unless the S3-SE had different exterior handles to my standard S3, I I don't believe that these would be particularly difficult to come by.
Skittle. 1967 Elan S3 DHC
- skelteanema
