Keys and locks
Hi Rod,
I have just checked mine; the boot lock is not the same as either the door lock or the ignition. The same key appears to operate both the door lock and ignition, but I do not know if the the ignition switch is original as a previous owner had started to redesign the dash and wiring but did not finish his work.
Ian
Ian
- RIB
I am an original owner of an S2. The car came with two keys - one operates the door locks and ignition and the other operates the glove box (cubby) lock and boot lock.
Herb
26/4618
Herb
26/4618
Herb
26/4618
26/4618
lotusS2guy - Second Gear
Thanks guys,
Thats 3 different answers to the same question.
Since mine has different door and ign locks I think Ill go with Jeffs answer.
Jeff is yours an S1?
Yes Rod, very early 200 chassis number, very original.
Check out my "what's it worth" thread for some photographs.
http://www.lotuselan.net/forums/elan-f14/what-worth-t25324.html
mazlot - Second Gear
Logically it makes better sense to have one key for door & ignition and a second key for glove box and boot.
It means that you can lock your private stuff away when you give the door/ignition key to the car valet at your posh hotel for him/her to garage & clean your Elan.
Henry
1967 S3 FHC
A joke a day helps you work, rest, and play.
1967 S3 FHC
- Henry VIIII
My ignition key opens the trunk (boot) as well. It doesn't open the glove box or the doors and I don't have a key that does so I never lock them. I seem to remember that my first S2 had 2 different keys, but don't know or remember what opened what.
- Tahoe
rodlittle wrote:Thanks Jeff
yours sounds nearest to mine, which is chassis 86 unit 3067
your pictures look superb, a rather better restoration than Im attempting.
I shall be happy just to be able to drive mine again
rod
jeff is exact i think..
led tubes
- Witimpen
