Just an idea
Just thought of this,if you are one who constantly worries if their nuts are tight,just a datum line in permanent marker on the nuts in line with the valve,,,simples,,,not foolproof though,next time you check it could have loosened off by 360 degrees..and for those perfectionists ,it just polishes off with Solvol Autosol..
John, most good ideas are simple. This is a good idea, and i will use it on my S4
James
James
....a small blob of Tippex for those of use with black wheels
'72 Sprint
'72 Sprint
- richardcox_lotus
[quote="richardcox_lotus"]....a small blob of Tippex for those of use with black wheels
Richard[/quote]
Richard....why?
Richard[/quote]
Richard....why?
Serves me right for not looking too closely - it seemed that you had also run a line onto wheel from the wheel nut.......blame it on the jubilee party yesterday
'72 Sprint
'72 Sprint
- richardcox_lotus
Hi John, your idea just adds another layer of safety. It is simple and Brilliant.
I just posted an idea for knockoff spinners -- not new-- but can be used as a convenience in the Business and Vendor listings section. It stops the wheels from spinning when applying torque to the spinners.
Keep those ideas coming.
Sarto
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
john.p.clegg wrote:not foolproof though,next time you check it could have loosened off by 360 degrees
John,
A nice idea, an alternative to a bit of Glyptal dabbed onto the knock-on nut and wheel. Off by 360 degrees? I guess that is the reason for your emoticon. One turn too tight = broken hub, one turn too loose = you'll already know the wheel is coming off.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Good safety tip, John!
Photo: Old aviation practice to prevent valve stem damage. Tire slippage while hard braking is common on small diameter rims.
More Aviation safety: http://www.ryanqc.com/tamperprooflacquer.htm
S-B
S-B
- spanner
