1964 Elan Restoration Project
• Page 2 of 4 • 1, 2, 3, 4
Yep Rod, put me down for one too if you ever decide to make some more. Beautiful work. I suspect the queue would stretch some distance!
Robert
Robert
- robertverhey
Yes, I need to definitely get in touch with the owner of the one in Wilmington!!!! I need to park it beside mine so I can put mine back together correctly!
What is the state of yours now?
TODAY'S UPDATE:
1) I replaced one of the flats, so I have 4 good tires now.
2) Checked the weep holes below the suspension spindles on the front (couldn't locate them in the rear). Plenty of dirt came out of them, but I was pleased to not see rust! Score!
3) Removed the plugs and tried to move the car to determine if the engine is seized. Car didn't move. Since the clutch pedal won't move one millimeter I agree with the earlier post that mentioned something about the clutch being frozen. Hopefully that is the problem and not the engine. But, if its seized, its seized. Our next step will be engine removal so we can give it a good going over. I'll know then if it is free or not.
Here's a shot from today:
TODAY'S UPDATE:
- Attachments
- Brad w Elan.jpg (21.15 KiB) Viewed 2019 times
Morgan Mehler
26/3656
26/3656
- UNCbigM
Sounds good. I think I'm in town that weekend so working on the car will hopefully occur. The next two weekends are autocross weekends for me, so that's likely the next weekend to get any real work done. I doubt I'll come across anything missing by then.
I know I will be needing some badges, as most of mine are broken. Oh and a dash pad. Hahaha.
As we get closer shoot me a PM and I'll give you my number.
Morgan Mehler
26/3656
26/3656
- UNCbigM
Hi Morgan,
Your car looked nice. The frame appears to be in excellent condition. Another original S1 "alive" and well.
Finding the engine number was fun too.
I'd try and get the engine running, if you can free up the clutch before hand all the better, rehab the hydraulics, back it out of the driveway and tool on down to the Cape Fear.
Eric
Eric
- 1964 S1
It's been a while since my last update. Progress has been slow for various reasons, but I'm very happy to report real progress! The engine is out! See below! I think our next step will be removal of the remainder of the exhaust and the transmission/drive shaft. I'm not sure if we will attack the engine after that or the suspension/brakes.
Any suggestions of the best way to support the rear on jack stands? Right now I've got a 4x4 going across the backbone and have the stands placed wide on that. The problem is the wood is in the way of the exhaust...
Morgan Mehler
26/3656
26/3656
- UNCbigM
Once you get things sorted, you need to be aware that it's not good to let the rear wheels "dangle" like that as it puts a lot of stress on the rotoflex couplings. Look underneath now at the extreme flex you're putting on the rubber couplings.
I expect you'll be replacing them anyway, but after you do, always support the suspension under the shock towers or a-frames, don't let the suspension hang unloaded like that.
Scott In Ohio
26/3795
26/3795
- 65 Lotus
Howdy Morgan, there are a few threads/subjects here on jacking an Elan and how to support the car.
The archives are alive.
Over the years I've used four by fours, and two by fours, and short notched four by sixes all in different configurations to hold up the rear body/suspension depending on the job at hand. Custom wood support.
I'd take your wheels off yesterday, less weight pulling your A arms down.
I'm a rotoflex guy, old fashioned and original, the Elans lose fluidity with CV's and gain? I dunno, hopefully the CV guys can let us know what is gained. If you think about the ENTIRE drive train I believe the rotoflexes enhance the Elan driving experience, even on my +2.
Good luck, throw the sunvisor in the ocean, lol, erc
- 1964 S1
How far up in VA are you Dean? I'd really like to see another Elan even somewhat local. I hear there's one here in Wilmington, but I don't know how to get a hold of them.
I love the idea of of replacing my rotoflexes, but I'm not sure if I want to continue with that maintenance. My car is going to be 90% original or more, as it nearly a complete car now, but my goal is not only to keep the car as original as possible, but also to have a nice driver that is as reliable as possible (ha).
I'm certainly open to ideas.
Morgan Mehler
26/3656
26/3656
- UNCbigM
Users browsing this forum: fatboyoz and 54 guests
