Help with finding this post
Hi all,
haven't posted for a while - just been muddling along.
A while a go I was looking through posts concerning the 'flexible' inlet manifold arrangement with 'O' rings and Thackery washers etc I thought I had saved it but can't find it on my PC. I have searched the forum but cannot find the one I was looking for.
Amongst all the posts someone said they had replaced the original arrangement with a rigidly bolted on inlet from another manufacturer (some older Nissan, Mazda, Pinto etc) completely doing away with rings, washers and air leaks. There was no evidence of frothing in the Dellorto's and it was much better.
Any idea where that post is please ? Or indeed what the inlet manifold came from and if there were any adaptations required ?
Thanks very much
Thanks very much
- seaandmoor
Found this thread talking about Stromberg rigid mounts...see Alex's post (Yum Yum) half way down page 1. Was that the one you were thinking of?
elan-f15/stromberg-carbs-t19540.html
S4 DHC
S4 DHC
- oldelanman
Thanks Roger but not that one I'm afraid.
I clearly remember it was a straight swap - remove the Elan inlet with 'O' rings and washers - then bolt the Dellorto's onto the replacement inlet and bolt the inlet to the head. No washers or 'O' rings, just gaskets and tight bolts. All the issues associated with the original arrangement dealt with in one go.
I just wish I could recall what vehicle the inlet came from - possibly one of the Honda range but really need to find the reply given (I think from the USA) to our poster who talking about problems with original inlets.
Keep trying everyone.
- seaandmoor
seaandmoor wrote: All the issues associated with the original arrangement dealt with in one go
What "issues" are you referring to? A solid mount will most likely introduce another set of more difficult ones to deal with.
seaandmoor wrote:Keep trying everyone.
Have been having a trawl but, sorry, no joy...apart from the opposite...
e.g. elan-plus-f13/carbs-meant-mounted-loose-t24019.html
- ardee_selby
Oh well thank you for looking.
I've got to get the carbs off soon to replace the pump and thought whilst I was at it I would do away with the fiddly rings and Thackery springs/washers.
That was the point about this other inlet bolted up solid so there wasn't any movement - it showed an improvement and no issues whatsoever. Fit and forget.
Do wish I could it again. Will have a look at PM's.
Thanks again everyone.
- seaandmoor
I have always been deeply suspicious of the wobbly mounts and frothing thing. OK so the engine thrashes about, are we supposed to believe that a sloppy mounting in some way dampens out that movement? I'm inclined to believe that the carbs wobble about even more.
Discuss.
Discuss.
Pete.
http://www.petetaylor.org.uk
Pete.
elansprint71 wrote:I have always been deeply suspicious of the wobbly mounts and frothing thing. OK so the engine thrashes about, are we supposed to believe that a sloppy mounting in some way dampens out that movement? I'm inclined to believe that the carbs wobble about even more.
Discuss.
I think it's the transmission of (resonant frequencies? natural harmonics? ) ermm high frequencies that cause the frothing problems, not low frequency wobbles...
(Please uptight your crabs and report back you're findings in dew coarse)
- ardee_selby
Discuss.
How about starting with this.
I thought it was quite interesting at the time but no-one seemed to take much notice.
free-parking-f19/origin-the-thackeries-t24310.html
Ralph.
- reb53
Users browsing this forum: JonB and 21 guests
