S2 Elan after 5 years -almost- on the road...
Hi all, after 5 years of searching all the big and -especially- little bits and pieces to finish my S2, the latest news are: She "was able" to see the daylight out of the garage and to feel the tarmac for the first time. I have to admit that I was not too happy with the first experience (never have driven a Lotus before!) because there are still a lot of stuff which do not work, brake pedal don't return completely, accelerator pedal not so smooth, front tires touching the body (front wheels/rims too big) etc etc. By the way: Is it correct that the clutch "touches" in the very last moment (just centimetres before leaving the foot)? I hope, most of the things can be sorted one day....
Best to you, Fred
Best to you, Fred
- ripley
Gorgeous color; very nice car!
Does the clutch disengage at the same location as engagement? My engagement point (assume that's what you mean by "touches") is mid range in its travel. If "yes", then it sounds as if your adjusting rod is way too long and there's no free play, ie, clearance between the throwout bearing and fingers of the diaphram.
Greg
Greg
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
@Bob: Thanks for your offer. Do you have any parts for sale? I'm desesperately looking for the big chrome/aluminium strip behind the seats/end of interior room, also for an original S2 rev counter (no matter what condition).
@gordont: Yes, these are 26R hubs/wheels from TTR.
@greg: Thanks. Don't remember but I think the clutch disengage at the same location. My engagement point is not mid but end range in its travel. Will check it out next time.
Fred
Fred
- ripley
[quote="ripley"]I'm desesperately looking for the big chrome/aluminium strip behind the seats/end of interior room, quote]
Is this what you are looking for? if so its listed at the type26 register http://www.type26register.com/misc_hardware.html
@George: It's exactly what I hope. Since years I was/'m wondering about all the positive and impressioned comments Elan drivers are mentioning about these cars. Wish mine will be one of them...
@types26/36: Yes, it's exactly what I'm looking for. But does anybody knows why none of my emails to the type26register has been answered? No chance to get a reply...
Fred
Fred
- ripley
ripley
Post subject: Re: S2 Elan after 5 years -almost- on the road... Reply with quote
Fred
The man behind the type26registry, Tim Mees died last July and I am not sure what has become of things since his passing. Maybe someone can fill in with an update?
free-parking-f19/tim-mees-passing-truely-saddened-this-news-t21054.html
Greg, When you write "adjusting rod", are you referencing the slave cylinder push rod? If it is, are you suggesting moving the nut down the length of the rod, essentially shortening the rod, to move the point on engagement up from the floor? Mine also engages somewhat close to the floor, but the more noticeable aspect, is that the engagement is very quick. No room for feathering. Thanks, Dan
Yes, I'm referring to the threaded rod coming out of the slave. There's a spec in the books that call for a certain amount of free play between it and the fork. This allows the throwout bearing to just clear the fingers. Ripley's problem is the opposite of yours. I suspected his to have pushrod adjusted so the throwout bearing is already into the fingers, hence the more immediate disengagement/ and engagement at the top of the pedal travel.
The lack of feathering is probably due to the type of clutch disc you have, ie, more toward racing specs than street specs.
Greg Z
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
Thanks Greg, that is what I suspected.
Those are a very interesting interpretation of the 26/R headlights. It looks like they might even work on dipped beam (unlike most others I've seen). Did you have the covers and mounts specially made?
Pete.
http://www.petetaylor.org.uk
Pete.
@elansprint71: I'm happy to see that my headlight "interpretation" finds interest. I prefer the perspex version but was unhappy when seeing all those little, modern high-tec headlights used by most of the racing Elans. Indeed my lights even work on dipped beam (sourced from Jaguar and modified after). The covers have not been modified but the mounts were specially made.
Fred
Fred
- ripley
collins_dan wrote:Greg, When you write "adjusting rod", are you referencing the slave cylinder push rod? If it is, are you suggesting moving the nut down the length of the rod, essentially shortening the rod, to move the point on engagement up from the floor? Mine also engages somewhat close to the floor, but the more noticeable aspect, is that the engagement is very quick. No room for feathering. Thanks, Dan
Dan,
It may be that your clutch needs bleeding - air in the hydraulics would also cause the symptoms you describe. While you are under the car checking the adjustment as Greg says it may be worthwhile to bleed it as well.
S4 DHC
S4 DHC
- oldelanman
