Dzus fasteners
A few years ago I saw a Elan that had a particular type of dzus fasterner to secure the hood (bonnet). They were mounted on each trailing side of the hood. They were recessed about an inch, so the actual "tabs" were below the surface line. Riveted in place on the topside, I believe was sort of triangular shaped, three rivets one at each corner. In the trailing corners of the engine bay were machined (hand made) pieces of aluminum that had the dzus wire. Does that sound like a 26R piece?? Hope that description leads me to a source for them.
Mike Summers
California
Mike Summers
California
- bluesbrother30
Mike,
It was not a 26/R item, however it was a very neat solution. Somewhere I copied the photos, the guy who owned the car is no longer on the forum. Incidentally, I don't think the fasteners were made by Dzus.
...zzzzzzzzzzzzzzzzzz....... found it..........
The file-name I saved it under was Oddie Pins, which may mean something, assuming this is the item you were looking for.
iirc, the owner of this car was also in Calif. I searched for these things in the UK but drew a complete blank.
- elansprint71
Yup, thats the one!!!
m
I searched that site and came up empty.........hope someone on the forum can ID the piece.
m
- bluesbrother30
I have these on my S2 bonnet, I will ask the previous owner (also on this forum) where he got them but I had thought theiy were Dzus fasteners with a "wing" attached to the top to open them.
I will take a pic for you.
nb - does this make mine a 26R.....?
Gordon
26/5416
26/5416
- gordont
I have just been to the garage to check and yes mine are DZUS fasteners too, will take a pic for you but look the same as the yellow cars fasteners but mine are in chrome
Gordon
26/5416
26/5416
- gordont
- gordont
- terryp
bluesbrother30 wrote:Hope that description leads me to a source for them.
UK source http://www.cbsonline.co.uk/search,b.html?q=dzus
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Hi Mike. There are some similar ones on Japanese Yahoo-Bay (Their equiv' to our Flea-Bay)
These are the Slot-Head type, as oposed to the Wing-Nut (Micky-Mouse-Hat) type.
Bit pricey at 8000-yen which is abouy 60-pounds for us Limeys......
John "Freddie" Nelson, Berks UK
26/3212 - Rebuilding
S4-Sprint DHC - Now at a new home.....
- Fredtech
I had an S2 Europa that had those "Triangular" fasteners to hold the engine cover on.
The were pressed stainless steel but the fastener was cadmium plated with just a screwdriver slot.
They did look very neat!
Maybe the Europa guys may know more???
Beware of the Illuminati
Here is an aero friendly version of the hood fastener: http://www.aerocatch.com/category_subli ... ocatid=158
- elancoupe
Good call John,
I know them as Oddie not Dzus - Banks Europa in the UK should have them, Bean use to have them . Lotus used them on race cars in period ( 30, 47) type 46 Europa ( boot and engine on the early cars) .
- cabc26b
cabc26b wrote:I know them as Oddie not Dzus - Banks Europa in the UK should have them, Bean use to have them . Lotus used them on race cars in period ( 30, 47) type 46 Europa ( boot and engine on the early cars) .
In a previous lifetime I always used Oddie fasteners for simple fixings for cabinet sides and doors for easy access for maintenance on industrial equipment. Dzus fasteners are slightly different, but the principle is the same.
http://www.savigny-oddie.co.uk/oddiefasteners.htm
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
I have the recessed hood pins installed on my S4. Sourced from Dave Bean.
When are you coming down this way?
Phil
1968 S4/SE FHC 36-7936
- pamitchell
Duh.............thats where I saw them, on your car. Last check was that the Beanery did not have any. Ken is researching. Tons of places to buy the fasteners themselves but none that I have found that matches the recessed holder.
mike
Brian, I tried the cbsonline.co.uk site but my computer blocks it, says it is a "alcohol and tobacco" site???? Or is that typical of most UK parts suppliers?
mike
- bluesbrother30
