Why restore an Elan
Famous Frank wrote:Many thanks Gordon. Once I cut the front end off, it was like loosing a limb, ......you have to get the prostectic on as soon as possible. It feels great!
I've got to say that I admire your bravery and perseverance. I think that if I had found what you found, I would have chickened out and parted it.
I understand that many paintshops have "baking rooms" to dry the paint. Have you considered baking the body for 12+ hours at 200 degrees to evaporate any moisture, just before final finishing?
Jim
Temporarily Elan-less
summerinmaine - Fourth Gear
By what I have been reading regarding the repair of glass fibre bodies any thing above 140F and the resin could start to flow and possible distort the body. Its is recommended that a force dry between 80F and 100F for about a week should suffice. That?s if you can find any one willing to tie up their oven for a week. Pretty costly too I would expect.
I stand to be corrected on this, just passing on what I have read regarding glass fibre body shells, repainting and the effects of low baking. Wouldn't like to see Franks car end up a melted blob
Regards MickG
Regards MickG
- MickG
Thanks guys, ....that's all I need, ............. I think I'll just keep it dry. It's been dry now for a few months and if I keep it dry for the rest of the year, it will be OK. Plus it will give me time to work on the GT6 Brakes, and the 5 speed T5, and the rest of the body work. As work in three of my jobs is spinning up, that leaves me time from 10:30 PM to 12:30 AM to work on the car. I better get at it!
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
MickG wrote:By what I have been reading regarding the repair of glass fibre bodies any thing above 140F and the resin could start to flow and possible distort the body. Its is recommended that a force dry between 80F and 100F for about a week should suffice. That?s if you can find any one willing to tie up their oven for a week. Pretty costly too I would expect.
Regards MickG
That low!!??!! I would have thought that the radiated heat from the mechanicals would have raised the temp at least that high during normal operations.
Jim
As I pointed out I am only repeating what I have read.
Take a look at this article about fibreglass repaires, in particular the paragraph "The Paint Systems", most of which you already know, but interesting non the less.
http://www.westfieldbuild.com/resources/Fibreglass.pdf
Regards MickG
Regards MickG
- MickG
Finally got a chance to jack up the o/s rear and get a picture of the scoop, but it won't add much to the store of knowledge.....certainly looks original and will need some repair! Dreadful idea, a stone catcher if ever I saw one! Maybe there are some pics of intact ones that can be loaded to assist in getting the profiles right. That said, I think Frank's probably got it pretty close (see his earlier posting)
Might scan that SCW road test and include in a posting.....it was, after all what made me fall in love with Lotus all those years ago.
Robert
Robert
- robertverhey
Robert, thank you for the great picture. Now that I see yours (and they seem to be looking very similar with the same portions missing I had a new idea. All this time I was thinking this is a diff scoop, ..............what was I thinking? It's a Donut cooler!!!
Frank
You are correct, I'd would like to see a pic of the forward most section as it left the factory. to make sure I get the contours correct.
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
OK, looking for a little technical help. The bonnet on this car also have many paint jobs and who know who has touched it in the past. And worst yet is I can't remember what is factory correct. Two questions if I may, ...1) The rear of the Bonnet has the two areas where the Bonnet latches. Is there suppose to be metal wrapped or attached in the latch area or do the metal Bonnet latches latch to the fiberglass.? And 2) At the front of the Bonnet, where the spring attaches, does the fiberglass have a notch cut into it or is it suppose to be enclosed all the way across the front.
This brings up another observation. Almost all of my previous S2 Elans, (I've had a few) had two springs holding the front of the hood in place. These two springs attached to the front frame bolts at the tops of the frame turrets. Now this S2 SE # 5738 has only one spring mounted in the center much like the later cars. And my old White S2 SE #5667 also had a single spring in the center but I assumed the previous owner made that modification. Is it possible all S2 SE's came with the single Bonnet spring in the center? Could any of you with S2 SE's respond with what type of Bonnet Spring you have? Two on the sides or a single in the center?
And if anyone could take a pciture and post it relating to the two questions above, it would be a great help. Thank you all ! Frank
- Attachments
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Frank
My S2 bonnet looks much the same as yours - pic attached.
Front has single notch and you can see the holes for metal plate or whatever - I do not use this at all so pretty much redundant
Rear has a notch at both sides - bonnet has been cut away to allow for the Deuz style fasteners
Gordon
26/5416
26/5416
- gordont
I just looked under mine for any trace - NIL.
Interestingly it appears that Roberts and Franks cars do not have a battery box protruding back which mine does, mine apears impossible to have the air scoop under the car as the battery box would get in the way. Know what I mean or do I have to crawl under and take a photo?
Gordon
26/5416
26/5416
- gordont
Gordon, thanks for the pics! Yours doesn't look anything like mine, ...........yours is all shiny and beautiful, ...... now about those legs in the bottom pic???
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Frank - I suggest painting it orange...
elan-photos-f18/hmmm-and-the-elan-ain-bad-either-t22055.html
Gordon
26/5416
26/5416
- gordont
I think I've fallen in love with orange !!! I'm going to blow that one up and look at the details more closely! Wow!
As for the Diff Scoop, mine only fits one side, .....the side opposite the battery box. Notice the attached pic, the battery box is on the right side and the diff scoop is on the left side.
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Here's my setup, looks like a bit of a home remedy by the PO
As you can see, women just can't wait to drape themselves across the bonnet. Caroline, in this case.
My battery box and the diff cooling scoop are both on the passenger side (Left side in a RHD car). The plot thickens.....
- robertverhey
