Judder on takeoff
I have had the problem for some time and cannot cure it .On takeoff I feel a judder through the clutch pedal ,if I give it some revs I don`t notice it ,it happens in 1st and 2nd.The car runs smothly and gear changes are normal .I fitted a new clutch last winter ,complete 3 piece,new engine/gearbox mounts,propshaft has been refurbished,rear susspension/diff mounts "seem" in good condition ,the diff housing is not touching the frame .Could the master/slave cylinders be faulty ,there are no leaks and I have changed the fluid .I used synthetic fluid ?
Regards John 1969S4DHC
- triumphelan
Hi,Suggest you take some time to explore this site!!go to homepage,look in the library section,and you'll find reviews of the elan when it was first released-the series2 review describes your exact problem!!
- purplepete
I seriously doubt the clutch hydraulic system is at fault unless it is obvious. More likely, it is one of two issues, either you are getting some oil on the flywheel friction face or the surface is warped. In any case, I believe you need to pull the engine and examine the friction surface. If the issue is oil cantamination, you need to refresh the rear main seal, clean the flywheel, and replace the driven clutch. If the flywheel surface is warped, you need to cut and rebalance the flywheel.
Sorry, no easy answers here.
Bill
Bill
- bill308
Users browsing this forum: h20hamelan, MartijnElanS4 and 23 guests
