Popping on overrun
• Page 2 of 4 • 1, 2, 3, 4
Hey John,
That's good news! Thanks for the feedback.
Let me warn you getting the new downpipe to seal against the exhaust manifold is a major hassle. Don't believe the manual were it tells you to just apply firegum there because that's a farce. I finally had to cutoff the poorly formed conical flare of the downpipe and weld on one I machined up. It had a 1-3/16" inside radius to match the male ball end of the manifold. The female piece had to made 1/8" thick so the two-piece clamp would not just smash it out of round before the connection was tight.
- type26owner
I`m hoping it`s a straight forward fitting job ,I will post my results
Regards John 1969S4DHC
- triumphelan
If there is only a single manufacturing source for the new downpipes, you're in for some trouble. The quality is poor.
Here's another tip. The cast iron two-piece clamp is directional. There is an arrow cast onto them that points up. You have to look very carefully to see it though.
- type26owner
I`m only replacing the rear box!!
- triumphelan
If it's the just muffler then you've most likely not found the source of the popping yet. Sorry! I'll stop trying to help now.
- type26owner
I've also got the popping problem, and have a slight headache from reading the amazingly complex replies from the forum's technical guru Keith, which made me more scared of the Webers than I already am.
But.... I'll see, because I actually enjoy the popping... Specially, like last summer:
In a tunnel, downhill, coming up behind a horrible yellow 500SLK with softtop on in the summer. Pulled out into the overtaking lane, got a bit in front of him and lifted my foot sharply off the pedal inducing a wonderful three-four pops/bangs. Down into 3rd and accelerated away briskly...
very satisfying.
Sorry about this post's lack of technical content
Thor
+2S130/5
very satisfying.
Thor
+2S130/5
- thor
I'm with you Thor,there's nothing better than a nice popping on the overrun-just increases the grin factor
Don`t stop helping Kieth ,all views are valued and evalulated
- triumphelan
If you're really into that effect why not add a fuel injector nozzle and a spark plug to the tailpipe. Then you shoot out a ten foot flame! Just kidding!
- type26owner
You've been watching too many James Bond films,but I might give it a go!!
I just have to make sure I'm back in front of the merc before I push the button (with a red flick-up cover of course..). hehehe
No honestly, I might still be down in the garage in the spring with a print-out of this topic trying to sort out the webers....
Thor
Thor
- thor
so---aside from the annoyance factor of popping on overrun---whats the problem ----lack of performance?-no --damage of internals? no---I just live with it --- ed
Users browsing this forum: mark030358, patrics and 41 guests
