Part suppliers (UK)
What part suppliers do people use to get parts for the Elan in the UK?
I have a few little jobs to do on the new Sprint, the most pressing of which is replacing the oil seal on the dear diff (prop side). I've searched here and hit Google hard, but the only thread I can find is this one which contain some numbers, but nothing on suppliers: elan-archive-f16/differential-oil-seal-t6111.html
Does anybody have a list of all the suppliers they use for various bits they'd mind sharing? I generally build up a list for each car, but this is our first Elan and it's proving quite hard just to get started with part numbers, let alone suppliers!
Dave
Dave
Dave
'06 Elise SportsRacer 111R
'72 Sprint FHC (and staying that way) - 0479
'65 XI Replica
[And a Subaru, but I don't think that counts ]
'65 XI Replica
StoatWithToast - Second Gear
I use Sue Miller in Suffolk and Paul Matty in the midlands. Between them they have just about all you'll need.
I always try Sue Miller first http://www.mickmillerlotus.com/intro.html - she is always very helpful stocks most things you need. Recently I needed some carpet pieces for my Sprint [but not the whole set] and she kindly cut a selected set for me, which was obviously cheaper than buying a whole set.
It is worth asking her to send you her latest parts price list
Lotus Elan Sprint FHC 1973
RichardS - Third Gear
Dave
Re parts numbers. If you do not already have them, do get an Owners Manual and the Parts List. I reiterate the posts above. Susan Miller as first port of call. If she does not have the part she will probably know who has.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Thanks all, have asked Sue for a catalogue to get me going.
Tim - I have the owners manual, a PDF of the workshop manual and I'm waiting on a copy of Brian Buckland's Manual. I've never heard of the Parts List until you just mentioned it. Any pointers on where I can get my mitts on a copy please?
I've just found this http://www.rdent.com/manuals/index.html from pointed to from here elan-f15/line-parts-list-enterprises-t16045.html is that good enough?
I prefer paper copies though - I generally end up getting oily fingerprints on the laptop and/or iPhone in the garage.
Cheers!
Cheers!
Dave
'65 XI Replica
'65 XI Replica
Dave,
You will be able to buy a service parts list from Paul Matty's-speak to Roy in the parts dept. The book is a large loose leaf/ring binder published by Lotus. it shows breakdown pictures of everything along with part numbers and applicability to each model. Excellent book to have-you could build a car from scratch just armed with it. (Consider it an adult version of an airfix kit instruction sheet)
Good luck and kind regards
Martin B
Martin B
- martinbrowning
StoatWithToast wrote: I've never heard of the Parts List until you just mentioned it. Any pointers on where I can get my mitts on a copy please?
http://www.mickmillerlotus.com/parts-manuals.html
Bought mine here: http://www.lotus-books.com/elan.html
Elan S4 DHC
E-Type S1 OTS
E-Type S1 FHC
E-Type S1 OTS
E-Type S1 FHC
- Heuer
www.sjsportscars.co.uk/
www.paulmattysportscars.co.uk/
http://www.spydercars.co.uk/
http://www.christopherneilpartshop.co.u ... N_2,l.html
That should keep you going for awhile; in my order of preference.
Jason
Jason
Jason1 - Coveted Fifth Gear
Jason1 wrote:http://www.mickmillerlotus.com/intro.html
http://www.sjsportscars.co.uk/
http://www.paulmattysportscars.co.uk/
Jason
Thats funny my preference as well. Order of preference based on experience with all!
Terry
- terryp
You should also be aware that Miles Wilkins supplies spares too. In fact his are all approved Lotus spares as he is the authorised dealer. You do need to call Miles as he does not do internet/email. But then you wouldn't get the full Miles effect through an email
Once you get talking to all the guys and gals at the various outlets you'll realise that they all share bits/suppliers anyway. As was the case at the beginning of the year no rear discs at one of them meant non of them had any! You'll also find they are all very fair- Spyder was sorting my hubs and I needed new axles from Kelvedon instead of getting them in and adding 10% they called me so I could arrange direct payment with Pat.
Personally I spread the parts around all of them. The more we keep in business the better. Plus it's fun to turn up to Miles's place with more Spyder bits on the car!!
Simon
Simon
Simon
'67 S3 FHC 36/7002
'69 +2 50/1370 (stolen '00)
'67 S3 FHC 36/7002
simonknee - Third Gear
And then you also have the shared parts (mini, Ford and Triumph):
http://www.minispares.com/
http://www.burtonpower.co.uk/
http://www.rimmerbros.co.uk/
http://www.canleyclassics.com/?xhtml=xh ... mepage.xsl
There are also others in the Business section on this forum.
There was also PDF files posted on this forum for Manuals and Parts lists for the different Elans, but they take a bit of searching for; if you have a few spare hours.
Jason
Jason
And this lot:
Auto Sparks: http://www.autosparks.co.uk/ (looms, wires, switches, grommets...)
Speedy Cables: http://www.speedycables.com/ (Smiths, overhaul ?50))
Nick Fulcher: http://www.coachtrimmer.co.uk/default.aspx (trim, steering wheels)
Fast Road Cars: http://www.fastroadcars.co.uk/ (weber, facet)
EBC Brakes: http://www.ebcbrakes.com/ (brakes)
Aldon Automotive: http://www.aldonauto.co.uk/shop/ (dizzy, weber, fuel nits)
Webcon: http://www.webcon.co.uk/ (weber)
Dellorto: http://www.dellorto.co.uk/ (lots of weber too)
Woolies Trim: http://www.woolies-trim.co.uk/ (trim)
Spring Masters: http://www.springmasters.com/ (springs, circlips, etc)
All used, all good. Many of these sites are worth a browse for things you never knew you could get and never knew you needed!
Simon
'67 S3 FHC 36/7002
'67 S3 FHC 36/7002
I used Dave Walker at emerald3d for my fuel injection system,and Andy Wiltshire for my fuel tank.Both lovely bits of kit.Competition Transmission services for the rebuild of my 5speed box and Leslie on this forum for a rebuilt diff with a 3.54 ratio.All good to speak too.Spread the wealth and everybody is happy....
- pauljones
