NO MORE DROOP !
PostPost by: Verve » Wed Apr 07, 2010 7:51 am
Well , having just seen first hand , the Failsafe System on a "Baby Elan" , I can only say how good is that !o!
No more droop , perfect instant synchronised lift , will always get you home ... and you could "flash" someone , before they`ve gone past for a change , if you like ; ) !
I didn`t realise how simple the system was ... one centre vacuum pod lift with spring , attached to a connecting rod between the two headlamps and away you go !
It`s so good , I`m seriously considering converting my Sprint ... and after all it is a Lotus Design and would be in the name of reliability , particular as I use my Elan for long journies to France etc...
So , does anybody out there ( maybe those across the pond either side ) , have a redundant mechanism lying around , or know where I can get one ?
Verve .
Sprint Drophead , Esprit V8 , 1978 Caterham Big Valve .
Verve
PostPost by: gjz30075 » Wed Apr 07, 2010 12:42 pm
Yes, it works well. The default position is up. Spring loaded up. Vacuum (car running) is down. A vacuum leak puts the headlights back up. So the system needs to be leak free if one wishes to have their headlights in the down position all day for, say, a car show.
Hopefully, someone can chime in with all the available parts to help you out.
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Verve » Fri Apr 09, 2010 8:03 pm
Thanks Greg ,
I would also need the dash vacuum switch .... so if anyone can help , out there ... please get in touch : )
Contact Paul on (01777) 702864 .
Verve
Users browsing this forum: JohnCh, mark030358 and 27 guests
