What is this?
My guess would be some sort of fabricated bracket to help support the heater unit BUT the fan mechanism would hot so perhaps check that is standard or maybe modified, looks like the fan would be about where the circular plate is.
Good luck
Good luck
Gordon
26/5416
26/5416
- gordont
It doesn't look like any brackets from my S4. The bottom mount for the vacumn tank is welded to the tank & the upper bracket just has one bolt hole at either end.
Keith Marshall
- saildrive2001
I'm puzzled by this "vacuum tank"; where is it supposed to be in an Elan? I only know of the the front chassis crossmember being used as a vacuum reservoir.
John Larkin
John Larkin
1967 S3SE FHC, 1974 Rover P6B, 1949 Lancia Aprilia
- John Larkin
Ok John
Vacuum Pod for the headlights
You and you're Elan jokes. One day you'll grow up and get a +2 (again!).
How are you??
Peter
How are you??
Peter
'73 +2S 130/5
'73 +2S 130/5
peterako - Fourth Gear
Hello,
it is the bracket for the vacuum pod for the fail-safe version. It was standard on federal version of S4 and Sprint. All other versions were with two pods; on federal version there is only one in the center of the nose and the two headlamps are connected by a rode. It work in the opposite way: when the engine is working the headlamp remain closed and when the car is parking the headlamps are open; if the vacuum sytem doesn't wark properly the spring connected to the pod open the headlamp automatically. Also the vacuum valve/switch on the dash is different, with two microswitches for the head lights.
This bracket is exactely the same that I heve in my car federal version.
Umberto
Umberto
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
Never knew that! Thanks Umberto.
John Larkin.
John Larkin.
- John Larkin
Users browsing this forum: RichardHawkins and 16 guests
