S1 Elan, what does this clip do ?
My S2 has a hardtop but doesn't have that clip. I guess it's a belt and braces job...an extra strap for the hardtop?
Its difficult to tell from your pic but I think you are refering to the lower "thing" that is pop-riveted to the frame and not the holes, the top hole is for the eyelet (cant rail) and used to fit the hardtop with a bolt after the eyelet is removed. No Idea what the other hole is for.
The "thing" looks like the base of a "lift the dot" fitting as used on soft tops and tonneau covers.
http://www.lotuselan.net/forums/viewtop ... 0140#80140
Some info I posted a while ago on hardtop hardware, with a couple diagrams out of the early Elan manual and photos of Andy Bodges hardtop hardware and one of my favorite photos of Beauregard . I should probably delete some of the info there but I guess I won't
Gary
Gary
Just had a thought, may be the other hole had a base like this (for a soft top) it became detached and the the other base was fitted???
- Attachments
- 542890249.jpg (2.31 KiB) Viewed 1260 times
- 251795_d.jpg (7.37 KiB) Viewed 1260 times
the lower hole and the bracket is not stock it is a rig by someone.
this photo that Brian posted below is correct.
Users browsing this forum: steponit and 24 guests
