ready to pull
• Page 1 of 5 • 1, 2, 3, 4, 5
a fine saturdays work ----motor is ready to pull out for total rebuild ---have to drain fluids and check to see what we will strength test with the hoist --- did you know a ground strap will lift a car ---??? ed
Hmmm, ground straps are supposed to keep your car grounded, not airborne.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Third Gear
Don't forget to drain the gearbox! Otherwise when you lift the front of the engine & pull it from the splines of the transmision shaft, lots of gearbox oil will pour out onto the floor.
Some looooong time ago I fitted a ring in the concrete roof of my garage for lifting the engine out and I have s simple hoist with triple pulleys at each end. It't tricky though as you have to tilt the engine sideways at one stage to clear obstructions (can't recall what off the cuff), and then upwards with the engine at about 70 degrees to the horizontal.
As my lift-ring is fixed I have to push the car back out of the way with the engine hauled as high as I can get it so that the back end of the gearbox clears the front fibreglass of the bonnet. And of course making sure that the swinging engine doesn't smash the windscreen. All rather hair raising.
here we go with the rebuild
here we go with the rebuild---removing the remnants of the old crank shaft needle bearing was a fiddley job --it was harder than a working girls heart --replaced it with a bushing ---ed
ok heres the holes filled with pistons
and the water pump and rear cover with seals etc ---Bill of Vallis motor sport carried on while I was gone and did his usual sterling job ------vallis motorsport 905 384 0016 ----the only one for ff- fv -f2000 and T.C. engines and the the best I know of --- -ed
Twincamman,
You say you had problems getting the roller bearing out of the crank, I`ve used very succesfully a brass or steel rod turned down to the dia. of the g/box input shaft, 3/4 filled the bearing with grease and then driven the shaft into the bearing,( hammer??), It hydraulics the bearing out.
Regards John.
Regards John.
The lines fall unto me in pleasant places, yea I have a goodly heritage.
- redskatejbf
thanks John ----sounds like a good idea ---next time -- -ed
Hi Bill ---I considered a cartridge pump but the 600 bucks is just a little steep right now --perhaps next time it fails ----but the bell housing was a priority this time ---ed
no progress today-- tomorrow the water pump rear seal and ancillaries are going on then the short block comes home and in ---the heat and humidity here is more conducive to turning the air conditioning down to about 40 degrees F and drinking Canadian while taping up hockey sticks - --ed
just added the bell housing --what a huge weight saving -[about 30.77 dollars a pound]--and its so pretty Im not going to paint it --with some luck the motor will be ready to install in short block form ---this week -------ed
That looks like beautiful work. Makes me wish it were mine.
- wojeepster
Users browsing this forum: dougal cawley, MAC2 and 46 guests
