Pertronix number
A friend who has a restoration shop I do some work for owes me for some minor work and has agreed to purchase a Pertronix for my S2. In looking through his catalog it is not very clear which unit is used with the 23D 41189 distributor. There is only one listing for the Elan. LU148. Is this the correct number or is there another number we should be ordering?
Thanks for your assistance.
Rob Walker
Rob Walker
- 264889socal
Try here for a good list (and good prices):
http://www.vintageperformance.com/retro ... /lucas.htm
I've got the LU-142A in my Elan and I really like it even though it partially failed on me last Sunday. The inner retainer on the magnet ring dropped allowing the magnets to move and a the engine to miss. I was able to put them back and use some duct tape to hold the ring together to get home. I reglued the ring and I will try a little plastic welding (hot soldering iron) to insure it doesn't do it again. My spare units are LU-142 which had a slightly different magnet location that would change the timing if I just swapped them.
Below is what Jeff at JAE had to say about the differences since the spare units I have came from him through a friend who didn't need them for his Europa Restoration.
> Hello Rob.
> The LU-142A is the same as the LU-142 but with the smaller
> module introduced about 6-7 years ago because the larger
> module can foul some rotor arms slightly.I have the original
> production LU142 in the 25D4 distributor in my Cortina MK1
> and I had to file on the plastic module to clear the rotor
> arm used in the original installation.Still working perfectly
> after nearly 14 years of constant use/abuse! The magnet rings
> have all been the same with the exception that they are
> supposed to be glued in addition to the press fit of two
> parts.The slightly different phasing of the magnets seems to
> ring a bell but it just means a slight timing adjustment
> after installation.The is now a LU-148 for the 23D4 dizzys to
> accomodate both type of breaker plates found in the
> centrifugal only advance distributors(points post or no points post).
> You should have no problem with using another LU-142/LU-142A
> magnet ring but my experience over all of these years with
> those units is that a drop of super glue would not be overly
> cautious on high revving engines.I've never had one come
> apart and while it's rare it's not unheard of .
> I think we have a couple of sets of points/condensors on the
> shelf but we rarely sell them anymore.I have no points in any
> of my dizzys anymore.Our new distributors have no provisuion
> for points and come equiped with Ignitor II systems in both
> vaccum advance and centrifugal only configurations.
> Regards
> Jeff
> Hello Rob.
> Regards
> Jeff
- Rob_LaMoreaux
Rob,
Thanks for taking the time and effort to get me this information. Since I have a 23D4 non vacuum advance, and have converted to negative ground, it looks like the LU-148 is the correct unit.
Rob Walker
Rob Walker
- 264889socal
