Lotus seen from down under
PostPost by: Emma-Knight » Thu May 03, 2007 3:52 pm
I took the chance to shoot a picture from the underside of the car...
There is quite a bit of work to do (I changed the brake light switch), the (missing) bracket at the rear end of the gearbox (holds up the front of the long exaust pipe) needs to be fixed, all suspension bushes would profit from replacement and parts will be repainted in process. The long copper clutch pipe behind the sump crossbar is a special from PO.
And there is an interesting shot of the factory made earth path through the opened steering coupling - no outside wiring needed! (risk of catching near parts)
Anna
earthpath through steeringcoupling.jpg and
Clutch slave bleeding position.jpg and
Lotus seen from down under.jpg and
1965 S2
Emma-Knight
PostPost by: steveww » Thu May 03, 2007 5:51 pm
That can not be a real Lotus Elan, there is not enough oil down there :wink:
steveww
PostPost by: blackandgold » Fri May 04, 2007 5:49 am
So where abouts in Australia are you ?
Hang on I throught you were talking about the Lotus scene downunder
:lol:
1973 +2 S130 with BDA
blackandgold
PostPost by: rgh0 » Fri May 04, 2007 10:35 am
Hi Anna
Just a comment looking at the photos of your very nice Elan.
The unsupported length of what looks like copper or cupro-nickel clutch hydraulic line would concern me. It will be vibrating with the engine running and you will ultimately get a fatigue failure.
