Lotus Elan
newbie to all this - ish
PostPost by: bruss » Thu Oct 05, 2006 5:44 pm
Hi All and first thanks for all the info on here - specially carb,cam and dizzy info. It seems getting the right combination thereof makes for a smooth running TC. I will ge there one day.
Meanwhile present request is for info on a car I've just bought. Its a 1977 (yes 77) elan dhc but with all the wrong numbers. Log book (pinks for US cousins) says Rebuilt - assembled from parts some of which were not new. Fair enough so probably a basket case (or two) re-assembled into one car in 1977. Q's are vin no is 36/7461 which indicates a fhc (not a 45 dhc) of around 67 vintage, and the engine no is L220268 which suggests around 1970. Anyone come across such a rebuild in the past? Although the reg (licence plate) number is age related to first registered 1977 (R plate). I'd like to try for an age related plate to the 67 or 70 vintage - any thoughts? Final q is that the donor car/s had a registration of JVW 529H, which dvla tells me is still out there but can't tell me whether it's a running car or just a log book sitting in someones draw/ Does anyone have or has had this car? Any info greatfully received.
Ciao
ps There is no head present so if anyone has a spare weber/dellorto head i'd be ever so pleased :)
68 plus 2 and 77? dhc - I'll take you out for a spin,- as soon as Ive got it working properly:-)
bruss
First Gear
First Gear
PostPost by: tower of strength » Thu Oct 05, 2006 11:19 pm
Hi Bruss,
sounds like bit of a bitsa you've got there!! Cant help with the I.D. of your car but here's a suggestion, If re chassied as part of a rebuild/repair in '77 the local licensing wallies may have issued a new Reg, hence the R plate. I heard of one in the 80's being allocated a Q plate for this reason(new chassis) until Club Lotus got involved and proved that the car is a monocoque with a sub frame!!, changeing a sub frame does not require an ID change.
As for the head, try Ebay, theres a couple on there at the moment, unless some one else can help?
tower of strength
PostPost by: tdafforn » Fri Oct 06, 2006 8:08 am
If you could persuade the DVLA it was the earlier '67 fhc then you could get free tax!
tdafforn
PostPost by: bruss » Fri Oct 06, 2006 9:19 am
Thanks Mark, an age related on it being a monocoque sounds worth investigating, and even better if I can get a 67 free tax disc Tim. Worth the cost of membership :lol:
Incidentaly I cleverly posted this thread on common and then on elan s1-s4 forums thinking of reaching a wider audience, but now I realise for clever read foolish 'cos I have to keep up to date with both. ( and am probably clogging the server oops sorry Jeff) :?
bruss
First Gear
First Gear
Users browsing this forum: pharriso and 22 guests
