Lotus Surplus Stock
Picked this up on Piston Heads, Lotus are selling off a bit of surplus stock.
Not too much T.Cam stuff but there are a few things people might be interested in i.e standard pistons @?20 each + vat (O.K if you are doing a 711 conversion) /breather elbow/tank sender/temp sender(+2) etc.
http://www.lotussurplusstocksale.co.uk/
It think this is list of all the Elan related parts available. The next to last figure in each row is the number that were still available towards the end of January 2006 and may not reflect current stock levels. The last figure is the UK? price INCLUDING VAT
PART NUMBER DESCRIPTION QTY LEFT SALE PRICE (INC VAT)
A026E0322Z Breather Elbow 240 1.25
A026E0712D Piston-Standard Gr4 (SINGLE) 36 22.99
A036C6002Z Bush-Lower Trunnion 1940 0.50
A036C6050Z Bush-Anti Roll Bar/Link 2960 1.00
A050M6136W Temperature Sender B2 500 7.99
LOTMOD0090 1:43 ELAN DHC (OPEN) CIRRUS WH 59 7.99
LOTMOD0097 1:43 ELAN DROPHEAD-B.R.GREEN 59 7.99
LOTMOD0100 1:43 ELAN COUPE-CIRRUS WHITE 84 7.99
LOTMOD0101 1:43 ELAN DHC (CLOSED)-CIRRUS 99 7.99
X026B0274Z Badge 'Lotus' (Script) 13 17.99
X026C0003Z Anti-Roll Bar 3 124.99
X026J6077W BRAKE MASTER CYLINDER 0 69.99
X036C6036Z Mounting Rubber-Damper to Roll Bar 4000 0.99
X036M6139Z SENDER UNIT 15 24.99
X050B0123Z Vacuum Cylinder LH-Elan+2 3 35.99
X050B0124Z Vacuum Cylinder RH-Elan+2 3 35.99
X050B0860Z Hinge Rod Assy 100 39.99
X050J6022Z Pad Set-Rear 20 22.99
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Third Gear
Cutouts on the pistons in the sale are 42mm inlet 38mm exhaust (on the left)
My old Hepolite ones shown for comparison are 37mm inlet 23mm exhaust but cut MUCH shallower
Picture edited after original posting
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Third Gear
tdafforn wrote:Hi,
the twin cam pistons mention small valve cutouts..
Does this mean that they are no good with big valve engines?
I've fitted pistons with much smaller cut outs then the one shown in Martin's pic to BV engines with no problems but it's still advisable to check the clearence while assembling.
I emailed lotus, and there reponse was
"Gr4(Single) - A026E0712D. This part is only adaptable for Mark 1. Therefore, it is not suitable for use in a big valve twincam.)
So I guess I'll have to pay full price for pistons for my 711m conversion
tdafforn - Fourth Gear
tdafforn wrote:"Gr4(Single) - A026E0712D. This part is only adaptable for Mark 1. Therefore, it is not suitable for use in a big valve twincam.)
Well Tim, if the one's in the sale are the ones in Martins pic (on the left)you are not going to get bigger cutouts than that or not in standard form anyway.
Those on the left *are* the pistons in the sale. I bought a set of them a few weeks ago along with a few other Elise and 90's Elan parts. I cannot see any fundamental reason why they would not work on any twincam although I'd suspect the compression ratio would drop quite a bit which might possibly be a good thing.
I only bought them on the basis that with pistons at 300-500 quid a set it would be significantly cheaper to fit liners to my block and use these standard size pistons at just 80 quid a set.
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Third Gear
I totally agree with Martin, here is a pic of a spare set I have marked:
A026EO712C grade 3
As near as I can measure the cutouts appear to be 42 and 37mm
A026EO712C grade 3
