Any good Christmas gifts?
PostPost by: JJDraper » Fri Dec 30, 2011 8:19 am
http://books.google.co.uk/books?id=F7al ... %22&f=true
Not full copies, but give a flavour of the books & why I am starting the campaign for my birthday.
Jeremy
PostPost by: Jas » Fri Dec 30, 2011 9:40 am
Yes the drill has a Morse Taper konus.
It's a Solberger Swedish made with 8 speed gearboks.
Just needs a Cleen-up and then something to drill :wink:
P1020986.JPG and
Jannik
1969 S4-SE DHC
Eat one live toad the first thing in the morning and nothing worse will happen to you the rest of the day.
Jas
PostPost by: elj221c » Fri Dec 30, 2011 9:55 am
Jannik,
That's not fair! Makes my Startrite Mercury look like something from the local DIY supermarket. :(
It does have a morse taper though and it's 10 speed. :wink:
On topic, lots of nice presents but nothing Lotusy.
Roy
'65 S2
elj221c
PostPost by: alexblack13 » Fri Dec 30, 2011 12:07 pm
Great.. Looks a good bit of Kit Jannik. You have to watch some of the really cheap stuff out there.
Great choice.. Is it 3 Phase? (400volts) All my kit is. I use a phase converter to power it all. Brilliant!
Alex...
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: Jas » Fri Dec 30, 2011 7:49 pm
Yes it is 3 phase.
Can you then adjust the speed with the phase converter?
Arn't they expensive for those watts?
Jannik
1969 S4-SE DHC
Jas
PostPost by: alexblack13 » Fri Dec 30, 2011 9:57 pm
It was not too bad price wise Jannik. Has been totally reliable too.. (should not have said that).... :roll:
Been great though. I used to agent them for use with wood machinery. So I got my own discount and a little more.
It is a std item and does not allow speed control (Not an Inverter) Which I don't need. My CNC lathe has vari feed and that's the only speed control I use. When I thought about 3 ph for my own workshop I had the option of a supply or the converter. It was the well cheaper option and I don't need to dig it up if I want to sell it. :lol: :lol: :lol:
Well done on your choice of machinery..
Here's a link to the makers of the converter I use....
http://www.powercapacitors.co.uk/Power_ ... ut_us.html
Happy new Year to all.. Keep well!
Alex B.....
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: alexblack13 » Fri Dec 30, 2011 10:19 pm
More info on converters..
The max HP motor I can run on my unit is 7.5 . OR multiples up to that figure.
I use a system with a 'donkey' motor.. I run that up 1st which helps to start the smaller motors that I use. larger HP motors can be run on their own and have similar starting to a star delta starter system.. The donkey motor is wired into a ring main around my shop with various plug / sockets (3 Ph) although now I never need to plug and unplug etc.. Machines are more permanently wired in now.. So I start the Donkey motor 1st and leave it running until I have started any other motors I need running. Then I knock the donkey off and tune the converter (via a switch 1 - 9 positions) to give smoothest running and least current draw. My lathe when running draws about 3 - 5 amps depending on work and speed etc. but sends the meter round to the stop when starting at high rpm's.. The workshop is fed via a 45 amp breaker.
I can do some pic's if anyone is interested. They do work very well.. :wink:
AB... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: alexblack13 » Fri Dec 30, 2011 10:22 pm
I am going to get me one of those steriophotowhatsit scope thingymagigs... :shock:
It might be available to borrow / hire... (Small donation as normal) Would that be of interest?
AB....
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: Bill » Sat Dec 31, 2011 1:59 am
Elanfan1 - the unadentified Welshman in Cardiff.
Silence is golden you say - take your silver duct tape and cover your a*s nd your mouth with it.
Your responce to twincam man was ireprehensipble.
Canada is no longer a Welsh colonie.
This is a forume to exchange Elan information and not to be vindictive!
Sorry your stick broke.
I think it best that you take a few weeks off pal!!!
B
B
Bill Rathlef
Vancouver Island, Canada
Bill
PostPost by: alaric » Tue Jan 03, 2012 7:27 pm
Hi. I got a tool box, but lost it moments later when my three year old decided that it was perfect as a toy box! Actually it's not that different a use just not full of my toys... Don't think I got anything ?lan related though.
alaric
PostPost by: Lotus fan » Fri Jul 13, 2012 11:20 am
Its July !!!
Lotus fan
PostPost by: c42 » Fri Jul 13, 2012 12:04 pm
Friend of Margaret!
c42
Previous
Users browsing this forum: No registered users and 61 guests
