ready to pull
• Page 2 of 5 • 1, 2, 3, 4, 5
A few things got in the way of finishing the engine ----sooooo looks like next week may see it ready to sling into the car --- -ed
more bits hung on ed
Hey Ed, whats with these double posts? I'm getting double vision now X
PS that black bit goes to the bottom
Black bit certainly does go on the bottom, and it needs a paint job .....
otherwise Ed's gonna see all his oil leaks .... he he !!
Stuart.
Stuart.
- stuartgb100
I stutter Brian you mean its not a single over head pan shaft engine ??? ed
ready to put it in ed
wellll ---the lump is back in ---single handed [ what a man ]-some times I impress even myself --going to consume many Molson Canadian tonight and button everything up tomorrow - --ed
all buttoned up ----- soon put the head back --set timing fill all vital fluids and more Molson Canadian --- then what?????cut the grass etc etc- -ed
have been tied up with the Europa licensing so now that I have it road worthy I can finish the elan ----so stay posted - -ed
were all gasket ed in place ---tomorrow the head goes on ---JUST A TIP --TO KEEP YOUR HEADERS FROM RUSTING SPRAY THEM WITH WD 40 once in a while --these are 40 plus years old -they will smoke a bit but wont burst into flame --honest --BTW ==Don Tingle has had a shoulder joint replacement so if you can send some good Karma at his email ADDRESS [email protected]---ED
getting there ---timing courtesy Mr Vice grip ----- ed
getting there --front lobes out and rear lobes in -o tdc and it all falls in place --timing courtesy Mr Vice grip ----- ed
closer ed
THATS A LITTLE NICER -----the valve cover was a 20 dollar find at a car show flea market ----was for a dry sump engine --so I removed the plug and fitted a V.W. after market filler that was kicking around [used J.B. weld ]----no more accidental oil cap leaks -- --and yes new fuse box and running the wires behind the fire wall are in the plans --- --ed
Users browsing this forum: No registered users and 47 guests
