Engine & Differential Detailing
Should the timing chain cover and associated backing plate be left "natural" or was it originally painted?
Same question for the rear aluminum differential housing?
Using the term from the parts book, is the color of the "hood sticks" (i.e. on a S1/S2 the metal rods running between the cantrails) Lotus Gray? In otherwords, is the color of the "hood sticks" the same color as the original engine block, sump and head? If so, I am in luck as my "hood sticks" have the original paint intact.
Thanks, johnc
Thanks, johnc
- johnc
Well, John. on my 67 S3 the metal top rails and sticks came gray, the
valve/sprocket cover was blue, front chain cover and alloy part of diff
housing unpainted. i have seen a lot of diff housings, and never saw one
where the factory painted the alloy part. George
On Fri, 6 Jun 2003 23:37:51 -0400 "John Connin" <***@***.***>
writes:
Thanks, johnc
writes:
Thanks, johnc
- gobw2
writes:
Thanks, johnc
writes:
Thanks, johnc
- gobw2
I have seen both, however IMO the timing chain cover etc looks better painted grey (and there is no such thing as Lotus engine grey), while I polishedmy diff housing simply to make it easier to keep clean.
Ray
-----Original Message-----
Sent: Saturday, 7 June 2003 15:38
To: ***@***.***
Subject: [LotusElan.net] Engine & Differential Detailing
Using the term from the parts book, is the color of the "hood sticks" (i.e.on a S1/S2 the metal rods running between the cantrails) Lotus Gray? In otherwords, is the color of the "hood sticks" the same color as the originalengine block, sump and head? If so, I am in luck as my "hood sticks" havethe original paint intact.
Thanks, johnc
This electronic email and any files transmitted with it are intended
solely for the use of the individual or entity to whom they are addressed.
The views expressed in this message are those of the individual
sender and may not necessarily reflect the views of the Christchurch
City Council.
If you are not the correct recipient of this email please advise the
sender and delete.
Christchurch City Council
http://www.ccc.govt.nz
Ray
To: ***@***.***
Thanks, johnc
City Council.
sender and delete.
- elanplus2
