Tall block front cover
Ed,
The tall block front cover assembly comprises a tall front cover and front cover backplate. This matches the deck height of the tall block, but the top should be faced off with the original or any lowered deck height. It avoids the requirement of using a separate spacer strip under the front of the cam cover, a source of oil leaks. The front cover is also manufactured to accept a cartridge water pump assembly, permitting the water pump to be serviced wothout removing the front cover and all the associated hardship that involves.
Burtons are a long established company in England who specialise in Ford type engines. Find then at www.burtonpower.com They also do a very useful hard copy catalogue.
Sean Murray
----- Original Message -----
To: ***@***.***
Sent: Saturday, April 12, 2003 12:46 PM
Subject: Re: [LotusElan.net] Re: 711M Main Caps
SEAN please enlighten me about the tall assembly front piece for the block and where is burtons thanks ed law----- Original Message -----
Sean Murray
To: ***@***.***
Foxie - Coveted Fifth Gear
ok thanks very much ed
To: ***@***.***
Sent: Sunday, April 13, 2003 8:32 AM
Subject: [LotusElan.net] Re: Tall block front cover
Ed,
The tall block front cover assembly comprises a tall front cover and front cover backplate. This matches the deck height of the tall block, but the top should be faced off with the original or any lowered deck height. Itavoids the requirement of using a separate spacer strip under the front ofthe cam cover, a source of oil leaks. The front cover is also manufactured to accept a cartridge water pump assembly, permitting the water pump tobe serviced wothout removing the front cover and all the associated hardship that involves.
Burtons are a long established company in England who specialise in Ford type engines. Find then at www.burtonpower.com They also do a very usefulhard copy catalogue.
Sean Murray
To: ***@***.***
To: ***@***.***
Ed,
Sean Murray
To: ***@***.***
