Clutch slave cylinder
Oh great wealth of knowledge....
Does anyone know the size c-clip that retains the clutch slave cylinder in the trans. housing.
Apparently I lost mine yesterday during a spirited roll in the countryside. Made for a very interesting ride home. Pushing through stop lights so I could pop it into gear.
Oh, the joys of owning a "classic" car.
The ride before the incident was spectacular though.
I could measure it but that means dismantling a lot. Thought I'd check here before getting into tearing things apart.
Briggs
Briggs
- Briggs1
Briggs,
The item you need is an external circlip with an inside diameter of 1".
Tools required are - small fingers, external circlip pliers, flat bladed
screwdriver ( to lever cylinder back into place ) and of course a jack.
Should take about three minutes start to finish. Good luck.
Ken W.
P.S. It would pay to check the retention lip on the slave cylinder has not
been damaged.
-----Original Message-----
To: ***@***.*** <***@***.***>
Date: Saturday, 28 April 2001 09:19
Subject: [LotusElan.net] Clutch slave cylinder
Ken W.
been damaged.
- "Ken Woodburn"
Just replaced mine this week. I found that a 1" dia. (inside measure) fit
just fine. The hardest part was getting it on with the exhaust in
place...very difficult to get at. Good luck.
Tim McKay
69 +2
Tim McKay
69 +2
- paulatim2869
AMEN to that. Sort of humbles you. You know how simple the job is and it
turns out to be a royal pain in the neck. Took me an hour to get the
circlip on and bleed the system.
Several times I wanted to call the engineer that designed it and ask him
what he was smoking the day they decided to put the slave cylinder
under/above the exhaust. (Maybe its just that I have headers?)
Amazing how a $0.39 part can ruin a day of driving.
Nice day out, gotta give it a quick cleaning and then a quick (not short)
drive.
Happy Saturday to all...
Briggs Pletcher
72 S2 Europa
67 S3 Elan
- Briggs1
Two more points which may help:
1. You actually need 2 circlips / snap rings to hold the S/C firmly in
place, one in each groove at either end of the S/C;
2. If you have to use snap rings rather than circlips (like I had to - 1"
is a big circlip and not readily available in these parts on a Sunday), then
I found that a piston ring fitting tool was the only thing that would get
the bl**dy clips on.
Hope this helps
Yellow 1970 Plus 2S - drove her 750 miles (12.5 hours!) from Chester to
Newquay (Cornwall) and back this weekend for a surfing stag weekend. 75-80
mph all the way, and she didn't miss a beat. Absolutely incredible! Lots
of folks on M6, M5 and A30 waving at us - was it you?
Ken W.
been damaged.
To: ***@***.*** <>
RPS Consultants Ltd
3 Linenhall Place
Chester
CH1 2LP
UK.
Tel +44 (0)1244 313486
Fax +44 (0)1244 317471
Part of the RPS Group plc - The Environmental Consultancy
This message is sent in confidence for the addressee only. It may contain
privileged information. The contents are not to be disclosed to anyone other
than the addressee. Unauthorised recipients are requested to preserve this
confidentiality and to advise the sender immediately of any error in
transmission. If you experience difficulty with receipt of the email please
telephone on 01244 313486 or fax on 01244 317471.
Hope this helps
Ken W.
been damaged.
To: ***@***.*** <>
RPS Consultants Ltd
3 Linenhall Place
Chester
CH1 2LP
UK.
Stevie-Heathie - Third Gear
Steve Heath wrote:
I believe that my Elan's slave cylinder has always had snap rings.
Installing/removing them is a snap (pun intended) using a pair of snap ring
pliers. Last time I looked, they were around $15 at Sears - don't know about
other parts of the world. They should be readily available, since you need them
to rebuild transmissions among other things.
Tim Mullen
Chantilly, VA
72 Elan Sprint
Tim Mullen
Chantilly, VA
72 Elan Sprint
Tim Mullen
72 Elan S4 Sprint - Colorado Orange over Cirris White
05 Elise - Colorado Orange
TimMullen - Third Gear
