speedometer cable woes
For the life of me, I can't figure out how my speedometer cable
reached the drive on the gearbox (LHD Elan S2). It seems to come up a
few inches short, no matter how I route it. Is it possible that I
lost a vital extension sometime during a loooooong restoration
process? Does anyone have any ideas or helpful suggestions?
Art
26/4934
Arther H. Frederick
Initial Reaction - embroidered and decorated apparel
3869 Route 66, Chatham Centre
Valatie, NY 12184
518-392-4287
Art
26/4934
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
Art,
The speedo cable goes to a right angle drive which is attached to an adapter
which is attached to the gearbox. My car came with those parts missing. The
PO had attached the cable directly to the gearbox using tiny Allen screws set
in holes that were drilled through the collar on the end of the cable.
Perhaps your car is missing the same parts. Best of luck.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
'71 S4 SE
Minnesota
- Frank Howard
<The speedo cable goes to a right angle drive>
The right angle drive is there as it should be, but the cable simply
isn't long enough any more! I've installed a replacement factory type
chassis, but I can't believe that it's enough different that the
relationship between body and gearbox has changed so much that the
cable no longer reaches. Everything else, including the gearshift
lever, is in the proper location. Is there an option for al longer cable?
Art
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
--- In ***@***.***, "Arther H. Frederick"
<initialreaction@...> wrote:
Art,
Are you saying this same cable worked (attached properly)on the
previous, original chassis?? Time for some measurements, if you still
have the old chassis.
Greg Z
'72 Sprint
Art,
Greg Z
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Unfortunately, the last time I saw the original chassis was about 15
years ago (some projects go very slooooooooowly X;{ ). But I'm not
going to worry about it. The same cable in a longer length was used
in various Spitfire models, among others.
Art
26/4934
At 10:49 AM 7/10/2006, you wrote:
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art
26/4934
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
