diff drive shafts
If you can send me an editable copy of the side view of the frame.I will
mark where I modified it.
Now this was my car.and I was unable to get the diff out of the car..either
way. It was then that I compared the tow frames.one old and the new one and saw the difference.
Tony Vaccaro
Tony Vaccaro
tvacc - Coveted Fifth Gear
Tony,
I'm curious to see this too. I bought a galvanized frame in 1983 and
could not get the diff in. I ended up taking a little bit of aluminum
off the top of the "Lotus" rear housing with a Vixen file and it fit
fine, but it wouldn't go in w/o modifying something.
- Elan45
Only the left side worked for me. Something to do with the lack of
symmetry of the diff in plan view?
Art
26/4934
Arther H. Frederick
Initial Reaction - embroidered and decorated apparel
3869 Route 66, Chatham Centre
Valatie, NY 12184
518-392-4287
Art
26/4934
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
My 66 S3 has its original frame. I have removed and replaced the diff twice, both from the left side. My frame has no indentations in it. The height (straightness) of the pan under the diff is critical. If it has been jacked from there, most likely it will be bent upwards, making the diff a very tight fit. I agree with Art's assessment; that the asymmetrical nose of the diff is what dictates that it be removed from the left.
Stan
36/5522
Stan
36/5522
- saarhus
It has been a long time, but, if memory serves, Lotus ReMarque printed an
article in the late-1970s on an alternative way of removing the drive
shafts. This required long bolts threaded through the ears and bearing
against the casing. One screwed up a nut on each bolt, bearing against the
ear, which then pulled the shaft out. That was how I removed the shafts,
and they came out easily. But that was over 30 years ago and my Elan was
justeleven years old.
Good luck.
Andres
1969 S4 Manila
Good luck.
Andres
1969 S4 Manila
- abstamaria
Andres
Yes, this will work. I have done similar "extraction" problem. If is less
costly, if you don't have a sliding hammer. (They are not very good for
Elan bodywork! Regular hammers are better!)
Ken
'69 Lotus Elan +2 with BDR
Ken
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
Jeff,
Another way is to use a length of studding thro each of the ears with a nut on the diff
side. Put some protective packing between the stud and diff housing and wind the nuts in
turn.
Bill
turn.
Bill
- bill_s708800
