Trim clips
Which way up do the trim clips which hold the horizontal trim below the
doors on the +2 go?
The "curve" at the top or the bottom?
I removed my original one's before painting........
Thanks in advance.
David
CONFIDENTIALITY NOTICE
The information contained in this e-mail is intended only for the
confidential use of the above named recipient. If you are not the intended
recipient or person responsible for delivering it to the intended recipient,
you have received this communication in error and must not distribute or
copy it. Please accept the sender's apologies, notify the sender immediately
by return e-mail and delete this communication. Thank you.
doors on the +2 go?
Thanks in advance.
David
- davidallen
Curve to bottom
set trim across upper tips; smash with rubber hammer to make it pop onto the lower rounded part. Just like the factory.
I made nylon buttons cause I wanted my trim sorta straight
_______________________________________________
Search for businesses by name, location, or phone number. -Lycos Yellow Pages
- "e s"
David,
The pointy ends face up. When you fit the trim back on make sure the angled
edge is at the top with, obviously, the rounded edge goes to the bottom.
Fit the trim in place at the toop then press in and downwards and the trim
should just pop into place. Just did this job last weekend! You'll also
need 3mm pop rivets to hold the clips on.
Hamish.
----- Original Message -----
Sent: Wednesday, January 25, 2006 8:52 AM
Subject: [LotusElan.net] Trim clips
Hamish.
Hamish Coutts - Fourth Gear
Thanks for your comments. I greased the top and bottom of the clips, hooked
the trim onto the clips at the top and gently tapped on the top edge with a
wooden dowel and hammer. This forced the trim into location and a very light
tap at the bottom clipped it into place.
No dents, damaged paintwork or swearing!
David
-----Original Message-----
Sent: 25 January 2006 19:42
To: ***@***.***
Subject: Re: [LotusElan.net] Trim clips
David,
Hamish.
David
To: ***@***.***
David,
Hamish.
- davidallen
Not much of a repair job without the swearing. Are you sure it's a
Lotus?????
BT
Of ALLEN, David
Sent: 2006/01/31 08:01
To: ***@***.***
Subject: RE: [LotusElan.net] +2 Trim
David
To: ***@***.***
David,
Hamish.
Lotus?????
BT
Of ALLEN, David
To: ***@***.***
David
To: ***@***.***
David,
Hamish.
- s2lola
One of the frustrations of being a part time mechanic is you only discover
the best technique to do a job after you have completed it!
Still, if ever you are fitting the sill trim on a +2, I am your man!
Sent: 31 January 2006 14:45
To: ***@***.***
Yes, isn't that cheating?
To: ***@***.***
- davidallen
