Re-built engine won't start
• Page 1 of 3 • 1, 2, 3
Hi all,
I have just put back the engine after ages rebuilding it. Miles Wilkins
did the bottom end, QED the top end, so everything renewed.
Turned over in the car, no go at all. New points, condenser and coil, so
I have good sparks. New plugs, and fresh petrol. Plugs smell of petrol
when removed so I assume petrol is getting in.
Timed static at 10 bTDC, But still does not attempt to fire. Points set
to 15 thou, plugs gapped at 30 thou.
Have I missed something obvious? Can I do a compression test cold? Will
this tell me anything?
Sorry about the post, but I really am at my wits end.
Kind regards
Jeff 72 +2
Kind regards
Jeff 72 +2
jeff jackson - Fourth Gear
Check needle valves in carbs. You may have one stuck shut................
-----Original Message-----
Sent: 2005/09/15 15:01
To: lotus elan net
Subject: [LotusElan.net] Re-built engine won't start
Hi all,
did the bottom end, QED the top end, so everything renewed. Turned over in
Kind regards
Jeff 72 +2
AVIS DE NON-RESPONSABILITE:
Ce document transmis par courrier electronique est destine uniquement a la personne ou a l'entite a qui il est adresse et peut contenir des
renseignements confidentiels et assujettis au secret professionnel. La
confidentialite et le secret professionnel demeurent malgre l'envoi de ce
document a la mauvaise adresse electronique. Si vous n'etes pas le
destinataire vise ou la personne chargee de remettre ce document a son destinataire, veuillez nous en informer sans delai et detruire ce document ainsi que toute copie qui en aurait ete faite.Toute distribution, reproduction ou autre utilisation de ce document est
strictement interdite. De plus, le Groupe Financiere Banque Nationale et ses filiales ne peuvent pas etre tenus responsables des dommages pouvant etre causes par des virus ou des erreurs de transmission.
DISCLAIMER:
This documentation transmitted by electronic mail is intended for the use of the individual to whom or the entity to which it is addressed
and may contain information which is confidential and privileged.
Confidentiality and privilege are not lost by this documentation having
been sent to the wrong electronic mail address. If you are not the intended recipient or the person responsible for delivering it to the intended recipient please notify the sender immediately and destroy this document as well as any copies of it. Any distribution, reproduction or other use of this document is strictly prohibited. National Bank Financial Group and its affiliates cannot be held liable for any damage that may be caused by viruses or transmission errors.
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
DISCLAIMER:
- s2lola
Just a maybe, are you sure that your ignition timing is not 180 deg out. If
you have spark, checked that the pump jets squirt fuel when opening the
throttle ) look into the carb choke with a torch while opening the
butterflies by hand) then the symptom indicates to the timing
Arno
_____
Of ***@***.***
Sent: 15 September 2005 09:01 PM
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
CopyrightC LotusElan.net and the author:
_____
* Visit your group "lotuselan
<http://groups.yahoo.com/group/lotuselan> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:***@***.***ect=Unsubscribe>
* the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
Internal Virus Database is out-of-date.
Checked by AVG Anti-Virus.
Version: 7.0.300 / Virus Database: 265.6.5 - Release Date: 2004/12/26
Arno
_____
Of ***@***.***
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
_____
* the Yahoo!
_____
- Arno Church
Arno,
Watch your choise of diction here! "Torch" probably results in a really bad
outcome over here in North America!
Sent: 2005/09/15 15:22
To: ***@***.***
Subject: RE: [LotusElan.net] Re-built engine won't start
Arno
_____
Of ***@***.***
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
_____
* the Yahoo!
_____
DISCLAIMER:
To: ***@***.***
Arno
_____
Of ***@***.***
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
_____
* the Yahoo!
_____
DISCLAIMER:
- s2lola
--- In ***@***.***, "Jeff@t..." <jeff.taylor-
jackson@t...> wrote:
Check fireing order 1342, rotor turns anti-clockwise.
You can do a compression check but unlikely it will show good specs
but shoul give some idea.
64Elan/72Sprint/Birkin T.C.Seven
Have you checked that the correct plugs are getting the spark at the
correct time. When I was burning the midnight oil rebuilding my TC I
had a senior moment and had my newly made leads going to the wrong
plugs but just couldn't see it at the time. Next morning the mistake
was obvious and the engine started first time.
Ken
Ken
- kandmpc
----- Original Message -----
To: ***@***.***
Date: Thu, 15 Sep 2005 21:21:56 +0200
My money is there.
Do check for live spark while cranking, not just 'oughta be'
_______________________________________________
Search for businesses by name, location, or phone number. -Lycos Yellow Pages
To: ***@***.***
My money is there.
- "e s"
Yes.been there and done that.
The only thing else I can think of..is in the dist..if you don't have the
fiber washer on the points.they will short out.
But assuming you have checked the gas.(ie spark plugs are wet) and you have
pulled a plug .grounded it and can see a spark.it has to be the timing.
There is nothing else that would allow nothing to happen.
Tony Vaccaro
_____
Of e s
Sent: Thursday, September 15, 2005 3:53 PM
To: ***@***.***
To: ***@***.***
My money is there.
Pages
http://r.lycos.com/r/yp_emailfooter/htt ... efault.asp
?SRC=lycos10
<http://r.lycos.com/r/yp_emailfooter/http:/yellowpages.lycos.com/default.asp
?SRC=lycos10>
SPONSORED LINKS
Lotus
<http://groups.yahoo.com/gads?t=ms&k=Lotus+note+crm&w1=Lotus+note+crm&w2=Lot
us&w3=Lotus+note+domino&w4=Lotus+notes&w5=Lotus+note+development&w6=Elan+hot
el+modern&c=6&s=122&.sig=2ocUg_Q24b4ublh6ea28mg> note crm
Lotus
<http://groups.yahoo.com/gads?t=ms&k=Lotus&w1=Lotus+note+crm&w2=Lotus&w3=Lot
us+note+domino&w4=Lotus+notes&w5=Lotus+note+development&w6=Elan+hotel+modern
&c=6&s=122&.sig=SNKRJ15rWu-uM-t5ZWzfEg>
Lotus
<http://groups.yahoo.com/gads?t=ms&k=Lotus+note+domino&w1=Lotus+note+crm&w2=
Lotus&w3=Lotus+note+domino&w4=Lotus+notes&w5=Lotus+note+development&w6=Elan+
hotel+modern&c=6&s=122&.sig=_B20pewfjcpQrykeFObCWQ> note domino
Lotus
<http://groups.yahoo.com/gads?t=ms&k=Lotus+notes&w1=Lotus+note+crm&w2=Lotus&
w3=Lotus+note+domino&w4=Lotus+notes&w5=Lotus+note+development&w6=Elan+hotel+
modern&c=6&s=122&.sig=MMeWHq812EsY4oACXICy7A> notes
Lotus
<http://groups.yahoo.com/gads?t=ms&k=Lotus+note+development&w1=Lotus+note+cr
m&w2=Lotus&w3=Lotus+note+domino&w4=Lotus+notes&w5=Lotus+note+development&w6=
Elan+hotel+modern&c=6&s=122&.sig=MoHxE0_pVQfBEYPKVNLVqQ> note development
Elan
<http://groups.yahoo.com/gads?t=ms&k=Elan+hotel+modern&w1=Lotus+note+crm&w2=
hotel+modern&c=6&s=122&.sig=OqVtcMMLn1B01x2LWGvxhw> hotel modern
_____
* the Yahoo!
_____
Tony Vaccaro
_____
Of e s
To: ***@***.***
To: ***@***.***
My money is there.
Pages
?SRC=lycos10
?SRC=lycos10>
SPONSORED LINKS
Lotus
Lotus
Lotus
Lotus
Lotus
Elan
_____
* the Yahoo!
_____
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
As Arno says, it is possible that the cam timing is 180 degrees out. Been there, done that (with an Alfa engine with mis-marked camshafts - my excuse,anyway!!).
KISS way of checking:
1) With the cam cover and spark plugs removed, turn the engine over on the front pulley until the rotor arm in the dizzy is pointed roughly at the contact for No. 1 plug lead.
2) Stick a screwdriver down No. 1 spark plug hole and gently rotate the engine on the front pulley to confirm that the piston is at TDC.
3) (and this is the bit where you kick yourself it it is wrong!) Check thatthe cam lobes are positioned in such a way that both valves on No. 1 cylinder are closed!
If you are feeling pedantic, you can repeat this procedure for Nos. 2, 3 and 4 cylinders, too, but unless you have some very unusual cams, this is irrelevant if No. 1 cylincer is timed in correctly.
Good luck!
Martin
To: lotus elan net
Sent: Thursday, September 15, 2005 8:01 PM
Hi all,
Kind regards
Jeff 72 +2
Good luck!
Martin
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
- Martin_StuartUK
On Thu, 15 Sep 2005 21:21:56 +0200 "Arno Church" <***@***.***> wrote:
AOL! I did this with my first ever engine rebuild. Rather than taking
a lump-hammer to the engine I thought about it for 24 hours before
acting. This was on a BMC A-series engine in a Mini, so I took out the
cross-crankcase drive shaft, turned it through 180 degrees and ....
....dropped it into the bottom of the gearbox ((
So, on my second engine re-assembly in two days I was somewhat more
conscientious.
Mike Causer Email - mailto:***@***.***
GPG KeyID 1C2DDA07 WWW - http://www.mikecauser.com
Flood the fen again! - Wicken Fen enlargement - http://www.wicken.org.uk
conscientious.
- mikecauser
All you need is spark, fuel and air.
So check them all.
Spark - Check with an inductive light on each wire - or remove and ground
and check for spark.
Make sure the plug wires are going to the right plugs (correct firing order)
Look for 180 out of time on dist.
Is the coil hooked up (wired) correctly?
Air - shouldn't be an issue- unless you have a SERIOUS filter clog.
Fuel - make sure the fuel pump is working.
Make sure the carbs are allowing fuel to pass.
After you figure it out it will have seemed obvious. Always does.
Good luck,
Briggs Pletcher
Of ***@***.***
Sent: Thursday, September 15, 2005 3:01 PM
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
So check them all.
Good luck,
Briggs Pletcher
Of ***@***.***
To: lotus elan net
Hi all,
Kind regards
Jeff 72 +2
- Briggs1
Hi thanks for all the replies!
I have sparks, checked them with a strobe light. they do appear at
around TDC.
My feeling is maybe 180 out, BUT, when I rebuilt the engine I did make
sure that the cam sprocket marks were adjacent at TDC.
number four cylinder, the cam lobes point toward each other, so cam
timing is ok ( I think).
What is this ballast resistor that goes on the coil? I had it on my
original coil, but replaced it, with another and the car still went.
My brand new coil doesnt have the ballast resistor... do I need it?
Other than timing could be the carbs I suppose.
Thanks for all the help. Will try again tomorrow!
Jeff
around TDC.
Jeff
People are not questioning your cam timing when they say 180 degrees out of
timing. What they mean is that you are firing at TDC on the wrong cylinder
(1 vs. 4 and 2 vs. 3). I missed a race once due to this error on my Super 7
(that was when I could drive better than I could wrench; now the opposite is
true.) All you need do is swap wires around and off you will go. If you
pull the valve cover and your distributor cover you should be ready to fire
the cylinder that has both valves closed i.e. compression stroke.
Ken
'69 Lotus Elan +2 with BDR
_____
Of ***@***.***
Sent: Thursday, September 15, 2005 5:40 PM
To: ***@***.***
Subject: Re: [LotusElan.net] Re-built engine won't start
around TDC.
Jeff
SPONSORED LINKS
Lotus
Lotus
Lotus
Lotus
Lotus
Elan
_____
* the Yahoo!
_____
Ken
_____
Of ***@***.***
To: ***@***.***
around TDC.
Jeff
SPONSORED LINKS
Lotus
Lotus
Lotus
Lotus
Lotus
Elan
_____
* the Yahoo!
_____
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
'84 Ferrari 400i
'94 Subaru SVX
'04 Audi allroad
- lotuselan2
On Thu, 15 Sep 2005 22:39:39 +0100 "***@***.***" <***@***.***> wrote:
Sure, but on a Twink the distributor is driven off the jackshaft (was
the camshaft in the Ford pushrod configuration). So the cam timing
marks don't come into it.
Have rebuilt three Twinks so far and not yet b*ggered one up. However
my time will come....
... but there's a parallel twin two-smoke [1], a Vee twin [2] and a Vee four [3] in
the queue first. Lots of FUBAR points on the table.
[1] English
[2] Italian
[3] Japanese
[1] English
[2] Italian
[3] Japanese
- mikecauser
With crank set to TDC and the timing marks on the cams lined up with each
other.. you insert the dist.the wire connection that comes from the coil
should be right at the 12 oclock..or closest to the head. You start
inserting it with the rotor (part that hits the connection for the spark) at
about 9 oclock. As you insert the dist..it will roatate clockwise to number
one cylinder. (about 10 oclock)
What I do then is put the crank to 12 degrees BTC and then put an ohm meter
between ground and that wire that goes to the back of the dist.
I gently turn the dist within its travel and you should get conductivity
.then none.turn it back counter clockwise so you get conductivity.and that
will be the correct timing. You now know that #1 is at about 10 oclock on
the dist..so put your #1 wire in there. Then keep going clock wise with the
correct firing order.
This is what we mean by being 180 out. Some people put the dist in wrong..or
put it in 180 degress out.
Tony Vaccaro
_____
Of Mike Causer
Sent: Thursday, September 15, 2005 6:17 PM
To: ***@***.***
Cc: ***@***.***
[3] in
[1] English
[2] Italian
[3] Japanese
SPONSORED LINKS
Lotus
Lotus
Lotus
Lotus
Lotus
Elan
_____
* the Yahoo!
_____
Tony Vaccaro
_____
Of Mike Causer
To: ***@***.***
Cc: ***@***.***
[3] in
[1] English
[2] Italian
[3] Japanese
SPONSORED LINKS
Lotus
Lotus
Lotus
Lotus
Lotus
Elan
_____
* the Yahoo!
_____
Tony Vaccaro
