Number plate
I need a new b/w rear number plate. What style of plates was current around
1970 in the uk?
White raised letters, pressed ally?
Ta,
David
CONFIDENTIALITY NOTICE
The information contained in this e-mail is intended only for the
confidential use of the above named recipient. If you are not the intended
recipient or person responsible for delivering it to the intended recipient,
you have received this communication in error and must not distribute or
copy it. Please accept the sender's apologies, notify the sender immediately
by return e-mail and delete this communication. Thank you.
1970 in the uk?
Ta,
David
- davidallen
Looking at photos in period road tests, black plates with separate raised plastic letters in white seem to have been commonplace. I'm sure that stylesand types varied, though, so just fit whatever you feel happiest with!
Martin
----- Original Message -----
To: ***@***.***
Sent: Wednesday, July 06, 2005 1:04 PM
Subject: [LotusElan.net] Number plate
1970 in the uk?
Ta,
David
Martin
To: ***@***.***
1970 in the uk?
Ta,
David
- Martin_StuartUK
On Wed, 6 Jul 2005 13:04:29 +0100 "ALLEN, David" <***@***.***> wrote:
Both, also stick-on letters for extra lightness and cheapness.
IMO pressed looks more "modern" than the plastic letters, but then those
letters are used at the front in the grille....
Mike Causer Email - mailto:***@***.***
GPG KeyID 1C2DDA07 WWW - http://www.mikecauser.com
Flood the fen again! - Wicken Fen enlargement - http://www.wicken.org.uk
- mikecauser
David,
Your car almost certainly left the dealer in 1970 with aluminium
plates with either silver or white raised plastic letters.
Pressed aluminium were the more "up market" and expensive alternative.
In my opinion the pressed plates look smarter and cleaner on the car.
They also look more "period" being the type fitted to cars for many years.
The decision would have been made largely on the type usually fitted
by the dealer unless the new owner expressed a preference.
My 67 had a black aluminum plate with cast aluminum letters painted
white. But then it was from the Bahamas. I still have the origianl
rear plate intact. Used the letters from the mangled front plate to
attach to the front grill. The Florida plate sports the same original
registration numbers.
Mike "no real help" Geiger
66 S3 Coupe'
--- In ***@***.***, "nebogipfel2004"
66 S3 Coupe'
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
As I was around at the timen I guess I should know what the correct plate
is! White on black and pressed ali were both available and legal at the
time but pressed ali was the fashion. If it helps, my 1970 s4, which I,ve
owned since the '70s, has recently been kitted out with ab new set of
pressed ali plates.
-----Original Message-----
Of Mike Causer
Sent: 06 July 2005 15:15
To: ***@***.***
Cc: ***@***.***
Subject: Re: [LotusElan.net] Number plate
pressed ali plates.
Of Mike Causer
To: ***@***.***
Cc: ***@***.***
ElanontheWolds - First Gear
My 66 S3 Coupe' was initially delivered in England and had the alu plate with raised plastic numerals (PNK 11D) on the rear and just the white plastic numerals attached to the black mesh of the grill opening.
Stan
pressed ali plates.
Stan
pressed ali plates.
- saarhus
66 S3 Coupe'
________________________________________________________________________
66 S3 Coupe'
Keith Marshall
- saildrive2001
