S4 headlight and turn switchs
Does anyone know what car the steering column hi/lo beam and turn
switchs come from?
Jim
switchs come from?
Jim
Triumph spitfire
Jacques
----- Original Message -----
To: ***@***.***
Sent: Wednesday, June 29, 2005 7:22 AM
Subject: [LotusElan.net] S4 headlight and turn switchs
switchs come from?
Jim
Triumph spitfire
Jacques
To: ***@***.***
switchs come from?
Jim
- lotuss4s
I ordered a steering column hi/lo beam switch from The Roadster
Factory, I believe is also listed for a TR-6. I found many TR-6
parts for my Elan in The Roadster Factory parts catalog.
Mike G
66 S3 Coupe'
--- In ***@***.***, "J & S Mazel" <lotuss4s@f...>
Mike G
66 S3 Coupe'
wrote:
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
And Herald Vitessa range.
The dip main switch is modified so that it is only dip/main. On the
Triumphs it also has a sidelight position.
Thanks to all who replied regarding my temp gauge, got a shiny new one from
holden, the bulb had a hollow bolt rather than a nut to secure it in to the
head, so I had to make an adapter...
Re: the light switch on the steering coulomb, mine has 3 positions, side -
dipped - main, it also has an off - sidelight - headlamp switch on the dash,
how was the coulomb switch modified for two position only?
TIA,
Jo 65 S2
Subject: [LotusElan.net] Re: S4 headlight and turn switchs
TIA,
Jo 65 S2
- hantsjo
--- In ***@***.***, "J. Lewthwaite" <imaa.co@v...>
Jo, not sure how it was modified the switch on my car and spare are
both Triumph. I would guess (knowing Lotus) that it is something
simple like an extended stop to prevent the switch selecting the third
position.
I considered modifying the stop on mine but didn't bother ..... too
many other more important prob's to solve!
Someone on the forum will know
position.
wrote:
Think I once looked at one and it had small metal tag/clip ? somehow
fitted to prevent it going to the other position, my S2 also has the
redundant position as I think the tag/clip falls out and gets lost,I
just dont bother to use that position.
64Elan/72Sprint/J.P.S.Europa/Birkin T.C.Seven
