Window motors
I am rewiring my Elan and putting relays in the window motors. Today I
wired the left door with the relays and it did not work, either up or
down. I tested the voltage and it was getting to the motor. Then I
applied wires directly from the battery - to the ground, and the + to
each wire on the motor (up and down). Still nothing. I then went to the
right door, which is still as originaly wired and applied voltage to the
appropriate wires running into the door - again, nothing. When I started
the re-wiring, both windows worked fine. What am I missing???
Thanks for any help.
Bob
69 Elan S4 DHC
Bob Bulfin, Professor Department of Industrial/Systems Engineering
207 Dunstan Hall Auburn University, AL 36849
(334) 844-1422 (Voice) (334) 844-1381 (FAX)
***@***.***://www.eng.auburn.edu/~bulfin
Bob
69 Elan S4 DHC
- bulfin
It is tough to say what you are missing.on line.
I would make sure you have a ground to the motor..then put 12 voits (from
another source. Making sure it is the same source that your ground came
from) to the up and down connector to see if the motor works.
Then I would do the same with the 12 volts from the car. This will tell you
if you are getting voltage from the cars system
Then.if it all works this way.all you do it put the same wire you touched to
make it go up and down successfully to the 12 (hot) power connector on the
relay. Then you put the "load" or in this case the window motor (either up
or down connector) to the load connector on the relay.
The other connectors on the relay are for the ground and the 12v from the
window switch. When you short out the window switch connector on the relay
with the ground.the window should go up or down. That is how you test if
the window switch is the problem.
Look at it all as a flow of water.or electrons.. In some form or fashion you
have to get 12v to the window motor.and then back to ground. You are
inserting a relay into the middle of all this..
Am I making sense..?
Tony V
_____
Of Robert Bulfin
Sent: Sunday, May 29, 2005 3:21 PM
To: ***@***.***
Subject: [LotusElan.net] Window motors
Bob
69 Elan S4 DHC
_____
Tony V
_____
Of Robert Bulfin
To: ***@***.***
Bob
69 Elan S4 DHC
_____
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
Looking at your post again.I would check the ground.
If you are getting 12 volts at the motor..only other thing it could be is
ground..
Tony
_____
Of Robert Bulfin
To: ***@***.***
Bob
69 Elan S4 DHC
_____
ground..
Tony
_____
Of Robert Bulfin
To: ***@***.***
Bob
69 Elan S4 DHC
_____
Tony Vaccaro
Bob,
When you connect 12V positive to one of the motor leads, the other motor lead should be connected to negative. In addition, the motor case is always connected to ground (negative). When the positive-negative connections to the motor leads are switched, the motor reverses in direction of rotation.
I believe there is a wiring diagram in the files (by Peter Wrisley) that shows the use of relays for the window motors.
David 72 Sprint DHC
----- Original Message -----
To: ***@***.***
Sent: Sunday, May 29, 2005 3:20 PM
Bob
69 Elan S4 DHC
David 72 Sprint DHC
To: ***@***.***
Bob
69 Elan S4 DHC
- dlbarnes1
Thanks to all for the help. Once I realized that one input had to be
ground, things got a lot easier. Using Peter Wrisley's diagram with the
relays worked great.
Thanks again; the people on this list are awesome.
Bob
69 Elan S4 DHC
Engineering
Bob
69 Elan S4 DHC
Engineering
- bulfin
