Colins quotes
and why aren't you?
been busy as my son had a lady pull out in front of him
writing off his Alfa 75 V6,
very messy but he walked away
scott
__________________________________
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
- twincamracing
Well Paul,
I did have a squeak in my rear springs due to springs buckling and scraping the shock tube. I had got a set of PTFE sleeves from Don Pringle in the US, which I intended to fit on the shock tubes. However when I went to change the rear springs (going to a higher rate) the max length available was 14", so I had 2" ally spacer made up to restore the ride height. (The original springs supplied by Spyder on the Spax adjustables were 16 ")
Result was that the shorter springs showed no sign of buckling and the squeak was gone !
Sean Murray ( with Sierra 5 speed )
----- Original Message -----
To: ***@***.***
Sent: Thursday, February 10, 2005 11:42 PM
Subject: RE: [LotusElan.net] Colin's quotes
Maybe the rest of the LotusElan.net are out driving along winding
mountain roads.
Leaving a trail of Porches and BWM's in their oily tracks.
Bob Metz is parked at a drive through trying to explain why his car has
no "Cup" holders. Super size or otherwise.
Rob LaMoreaux is trying to measure the luggage capacity of his Elan -v-
his Corvette
65 Lotus was hurt in a bizarre "Gas tank" welding experiment
ardee_slby is trapped by defective door stays
Brian Goodison is still perplexed by his gearbox
Briggs Pletcher is looking for a windshield
***@***.*** in Africa or someplace.
e s is playing at a re-wire.
Edwards Ray, is gluing a model Elan together
elanspring71 is struggling with his bad back.
Ian Phillips is attempting to measure the tensile strength of 1960's
1/4" bolts. (We want a graph)
Brian Gush is trying to get an S4 bonnet (hood) to fit an S2..........
eFFing Ian is gazing a grazing sheep.
Trevor can't get his starter to start.
Gareth is busy changing his wheels.
Scott potter's looking for a grommet
Sean murray's got 5 speeds and a squeak
William "kip" king can't get his dipping stick to seal
<Drum roll>
At the end of the alphabetical list.....
Zuckerman tells us that "Land Rover is owned by Ford."
Get out more Zuckerman!
Paul <Needs a new hobby> Adamson./my squeak
To: ***@***.***
mountain roads.
his Corvette
<Drum roll>
Foxie - Coveted Fifth Gear
