Seat belt choice
>The only difference being you get less wet when it rains.< Well, maybe in
your car.....
Art
Arther H. Frederick
Initial Reaction - embroidered and decorated apparel
3869 Route 66, Chatham Centre
Valatie, NY 12184
518-392-4287
your car.....
Art
Arther H. Frederick
Valatie, NY 12184
518-392-4287
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Fourth Gear
This is a very interesting discussion on an area which I have spent no time,
(other than replacing the mounting plates because they had rusted away!)
Am I correct in believing the problem is in the event of a crash, some
designs hold your shoulders back in the seat and consequently, your body can
slide under the lower belt?
If this is so, what is the optimum design for a conventional 3 point belt? I
would take the approach of having the belt professionally modified (no, I
would not do it!) or moving the location of the mounting points. Are fixed
belts better?
David
-----Original Message-----
Sent: 02 November 2004 18:51
To: lotus elan newsgroup
Subject: [LotusElan.net] RE: Seat belt choice
The only .and I repeat only..safe set up is the stock unit but not that
great.or a set of 6 points.with a crotch strap that you attach to the same
place as the lap anchors.and you actually SIT on the crotch belt.and it
attaches to buckle..
I have a set in my Seven.if you want pictures. I have 4 point in my
Elan..and I am always afraid of submarining under the belt.I am sure I
would..
Tony V
Tony,
This is not entirely correct. The belts in a 5 or 6 point harness cannot
eliminate the forces that produce submarining. The transfer of mass still
occurs- albeit to al lesser extent.
In the dynamics of a crash the most effective preventative measure for
submarining, not respective of belt configuration, is to increase the
incline of the seat pan.
Submarining is set in motion by an unimpeded horizontal sliding of the
drivers lower mass accompanied by the fixation of the upper body by the
shoulder belt(s). In order to prevent submarining the drivers mass must be
located top and bottom. This can be done by increasing degrees with a
3,4,5,or 6 point harness. It can also be accomplished by loading that mass
into a surface that will counteract its motion, or better yet a combination
of the two approaches. Additionally, a 5 or 6 point harness will locate
the driver with minimal excursion - BUT - the loads on the belts will be
significantly higher than if the harness is used in conjunction with an
inclined seat pan.
Been there - crash tested that. The dummy died of internal injuries.
Period.
Bottom line - these are old cars, and the belts they came with (while better
than nothing) are still 40 years behind the current understanding of crash
dynamics.
You have to do your own research and make your own decisions on safety.
Please drive safety, the world needs more Lotus fans...
-E
1969 FHC 8624
belts better?
David
would..
Tony V
Tony,
inclined seat pan.
Period.
dynamics.
-E
1969 FHC 8624
- davidallen
David - The issue is that 4, 5 or 6 point belts where your shoulders are
both held back equally can cause you to submarine - particularly on the
"rebound". Correctly installed crotch belts will help, but they cannot be
properly installed with a stock Elan seat - you need a race seat where you
are literally sitting on the crotch belt. All you do with the belt wrapped
around the front of the stock seat is build up momentum before they get
tight - OUCH!. And who is going to religously put them on in a street car?
Three point belts are designed so your upper body twists, which keeps you
from submarining under the lap belt. The original Elan three point design
would have had to meet federal guidlines at the time. But, I would be very
worried about an aftermarket system that isn't set up to meet the
specifications called for by the unit. In particular, I would suspect that
the stock mounting points aren't correct for ANY aftermarket belt. I use
Schroth belts in my track car and went carefully through the proper mounting
process with the Schroth US supplier here in Boston. I have also seen many
videos from Schroth tests showing submarining with incorrect installations -
they are not very pretty. This is not something to "home engineer". If you
want to move away from the stock belts I strongly advise that you talk to a
knowledgable supplier, not someone who will just sell you some belts. Here
in Boston that would be HMS Motorsports.
66 Elan S3 DHC
88 BMW M3 Track Car
----- Original Message -----
Sent: Wednesday, November 03, 2004 8:01 AM
Subject: RE: [LotusElan.net] RE: Seat belt choice
belts better?
David
would..
Tony V
Tony,
inclined seat pan.
Period.
dynamics.
-E
1969 FHC 8624
66 Elan S3 DHC
88 BMW M3 Track Car
belts better?
David
would..
Tony V
Tony,
inclined seat pan.
Period.
dynamics.
-E
1969 FHC 8624
66 S3 DHC
66 S3 DHC
- john66s3
I have had luck with Moss Motors having the original style 2 and 3 point
belts with reels, etc. - John
Sent: Wednesday, November 03, 2004 2:37 PM
Subject: Re: [LotusElan.net] RE: Seat belt choice
Where can I get replacements for the 3-point belts in my 1969 S4?
Steve B.
Steve B.
66 S3 DHC
66 S3 DHC
- john66s3
