Grounding the horn
Is there anyway to get to the steering joint to ground the horn
without pulling out the radiator? Thanks. Dan
I could not find a way when mine came loose. I ended up using a long
drift and tapping against the edges of the flats of the nut/bolt.
How long it will last I have no idea, but my hone does work again.
Mike G
66 S3 Coupe'
--- In ***@***.***, "collins_dan2000"
Mike G
66 S3 Coupe'
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
I grounded my horn by fitting the ground wire under the grease
nipple on the steering rack. It is in front of the radiator bottom
tank.
Phil
69 S4
-- In ***@***.***, "Michael Geiger" <type36lotus@v...>
tank.
Phil
69 S4
wrote:
Phil
1968 S4/SE FHC 36-7936
- pamitchell
Dan,
I replaced a broken earth wire on the steering U/J my Plus 2 (in Milan) two weeks ago, using axle stands, a 1/2" ring spanner and a 1/4" drive rachet spanner with a 4" extension. Now that I'm home also just noticed that there is access from the right front wheel arch.
Ever experienced driving in Italian rush hour city traffic with no working horn ? Not to be recommended !
Sean Murray
----- Original Message -----
To: ***@***.***
Sent: Friday, October 22, 2004 6:45 PM
Subject: [LotusElan.net] Re: Grounding the horn
Mike G
66 S3 Coupe'
Sean Murray
To: ***@***.***
Mike G
66 S3 Coupe'
Foxie - Coveted Fifth Gear
