Donut Replacement
Elan enthusiasts -
When I replaced my Diff seals 2 weeks ago, I obviously had to remove and replace the donuts. I was lucky and used regular old Stainless worm (Jubilee?) clamps from Home Depot to compress the donuts - which is critical - as they expand about 1/8 inch radially when uncompressed. The order of installing donuts discussed a few days ago is also correct, according to my trials and tribulations. I also jacked up the strut to get them as level as possible but ended up just lifting the car and they were never aligned just right. In retrospect - I should have put 200 lb of horse feed or lead or a neighbor in the boot to get everything lined up perfectly. I used a #3 phillips screwdriver to slign the holes - which occured in the topmost position. As others said - get all three bolts in first - then put on the nuts. Good luck - it's a devil of a job. Next time - I'm moving to CV joints.
Paul
65 S2
Paul
65 S2
- brassringfarm
A good tip is to use three smaller jubilee straps rather than one big
one. This allows you to adjust each screw on the Jubilees to help align
up the holes.
***@***.***e:
Steve Waterworth
Einstein: "The faster you drive, the slower you age..."
up the holes.
***@***.***e:
Steve Waterworth
steveww - Coveted Fifth Gear
This is why I am removing the donuts (Replacing the Diff seals/bearing).
Any other tips you discovered?
I have heard a lot about the output seals failing, but not the input. Is
this less prone to failure?
David
-----Original Message-----
Sent: Tuesday, May 11, 2004 2:16 PM
To: ***@***.***
Subject: [LotusElan.net] Donut Replacement
Elan enthusiasts -
joints.
Paul
65 S2
CONFIDENTIALITY NOTICE
The information contained in this e-mail is intended only for the
confidential use of the above named recipient. If you are not the intended
recipient or person responsible for delivering it to the intended recipient,
you have received this communication in error and must not distribute or
copy it. Please accept the sender's apologies, notify the sender
immediately by return e-mail and delete this communication. Thank you.
David
To: ***@***.***
Elan enthusiasts -
joints.
Paul
65 S2
- davidallen
It is my understanding that the donuts not only allow the axle to bend as the wheel moves up and down, but to change slightly in
length. (This has been accomodated in other cars with a splined halfshaft.) If you go to a CV joint, the shafl length is then fixed and
some strain will be present on the suspension components.
Am I wrong or is there something I am missing?
Steve B.
--- In ***@***.***, ***@***.***e:
Steve B.
Steve B.<br>1969 Elan S4
- poiuyt
The CVs that I have used..(the bean unit) have a sliding spline incorporated
into the design.
Tony V
_____
Sent: Tuesday, May 11, 2004 12:17 PM
To: ***@***.***
Subject: [LotusElan.net] Re: Donut Replacement
Steve B.
joints.
CopyrightC LotusElan.net and the author.
into the design.
Tony V
_____
To: ***@***.***
Steve B.
joints.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
Further to all this
There are two types of the Lobro style CV joint
1> the "plunging" type , as fitted to both ends of the drive shaft of rear wheel drive IRS cars such as the Beetle, Microbus/Kombi, Ford Sierra etc
as well as on the inner end of a FWD cars
2> the "knuckle" type which is fitted to the outer end of FWD cars and thisallows steering movement.
as we all know , steering movement is far more than plain droop movement that the plunging type can accommodate
On my (now sold ) Elan S3 I used the small Golf MK 1 plunging type - no problem
When establishing the length of the shaft , I made sure that the required measurement was taken with the suspension at ride height and with the centreof the inner "race" of the CV joints located centrally within the outer "race"
This would then allow for equal droop and rise movement
Finally, the CV joint is a very clever "animal" , far superior to the universal joint
Just make sure you buy NEW and not second hand or reconditioned
In S/H joints that have not been abused , it is difficult to spot wear.
Normally , it is only the grooves that will show wear and not the balls
In recon units , the grooves are actually machined slightly oversize to getrid of wear and the oversized balls (no, not the ones you need to become asuccessful racing driver) are used.
Arno
----- Original Message -----
To: ***@***.***
Sent: Tuesday, May 11, 2004 6:28 PM
Subject: Re: [LotusElan.net] Re: Donut Replacement
CV joints allow for in/out movement as well as angular movement.
Arno
To: ***@***.***
Steve B wrote:
- Arno Church
Yes there is, the CV joint is so cleverly designed that they also can move sideways to accommodate the "lengthening effect" of suspension movement
The joints I used could move about 15 mm sideways from it's central position
Arno
Steve B.
Arno
Steve B.
- Arno Church
Has anyone had experience of the spyder drive shafts, which have a fixed
(non sliding) shaft, a UJ and retains one donut.
I guess the theory is that the variation in the length of the drive shaft
will be taken up by the single donut, but would not this result in the donut
flexing more than the original setup, and consequently more likely to fail?
David
Sent: Wednesday, May 12, 2004 8:00 AM
To: ***@***.***
Further to all this
problem
"race"
universal joint
Arno
To: ***@***.***
David
To: ***@***.***
Further to all this
problem
"race"
universal joint
Arno
To: ***@***.***
Steve B wrote:
- davidallen
I had those on my spyder built car many years ago. I did not put them
on..but they worked fine.more like the feeling of the original car than the
"pure" sliding splines with CV...but I had those as well on my other Elan
and they were great.from Bean. I noticed last night that RD has them as
well for about $1250,,,,
I paid about $900 15 yeara ago,...so that is not so bad..
Tony V
_____
Sent: Friday, May 14, 2004 4:34 AM
To: ***@***.***
Subject: RE: [LotusElan.net] Re: Donut Replacement
David
To: ***@***.***
Further to all this
problem
"race"
universal joint
Arno
To: ***@***.***
Tony V
_____
To: ***@***.***
David
To: ***@***.***
Further to all this
problem
"race"
universal joint
Arno
To: ***@***.***
Steve B wrote:
Tony Vaccaro
David,
I fitted Spyder CV/donut shafts twelve years ago. The Spyder conversion has a CV joint as distinct from a UJ, mounted on splines which slide in the CV.
Before this I used carry spares donuts I had to change them so often.
Since I fitted the Spyder shafts I haven't had to touch them since, they seem pretty bomb-proof.
Sean Murray
To: ***@***.***
Sent: Friday, May 14, 2004 9:33 AM
David
Sean Murray
To: ***@***.***
David
Foxie - Coveted Fifth Gear
