bonnet foam strip
--- In ***@***.***, "Johan Thoren" <sotul86@h...> wrote:
Hi, all -
My simple solution was to go to a truck tire service shop and
beg an old discarded truck tube. I got one that was nearly
intact and cut an 18" x 3" section to make the lower rad
deflector. It's heavy, stiff rubber and can be easily cut
with a box knife or heavy scissors to provide a perfect fit.
I used liberal amounts of silicone RTV to hold it to the
contours it had to match, and it provides a near-perfect seal.
HTH>
Best regards,
Bob
__________________________
Hi, all -
HTH>
Best regards,
Bob
<span style='font-size:9pt;line-height:100%'>Best regards,<br>_<span style='font-size:13pt;line-height:100%'><span style='font-family:Times'><i><b>Bob</b></i></span></span><br>______________________<br>[email protected]</span>
LotuSport - Third Gear
Hello Mark,
When I said it was only on Sprints I was quoting from the
w/manual "to further improve the cooling system,Sprint models are
fitted with a blanking plate panal" although the parts list shows it
was fitted to S4 S4FED and Sprints but not S3s. I have not seen it on
S3s but am quite willing to accept the fact as after 30 years who
really knows.I agree it would be difficult to fit a flat one as it
curves around the rack, mine had disintergrated so I made an alloy
one.I would be quite interested to see your pic's of
your "oddball" panal.
Regards Brian
64Elan/72Sprint/J.P.S.Europa
-- In ***@***.***, "Mark Spiers" <elansprint3@h...>
wrote:
out and the narrower Triumph Herald Stanpart radiator was used with
the side blanking panels bolted to the radiator. With a smaller
radiator maximum airflow through the radiator was found to be
required, hence the deflector panel under the radiator, but there are
several variations of pattern. My S4 had an oddball one that I had
only seen on two other S4's, but Paul Matty in the UK sells a die cut
pressed panel which they swear is THE original shape (don't agree
really and it is hard to fit as it comes as a flat sheet).
Regards Brian
See page "KA" in the Elan parts manual- it's just an odd shaped bit of bentfibreboard with an elongated hole for the bonnet spring.It is not shown inmy Workshop Manual.
Pete
----- Original Message -----
To: ***@***.***
Sent: Monday, May 19, 2003 2:01 AM
Subject: Re: [LotusElan.net] bonnet foam strip & "deflector"
At 07:00 PM 5/15/2003 +0100, Mark Spiers wrote:
Pete
To: ***@***.***
Pete.
http://www.petetaylor.org.uk
Pete.
OK, Brian,
I'll get the digital camera from work this weekend.
Rgds,
p.s. Are you in UK? I am at Castle Combe this weekend
To: ***@***.***
Sent: Monday, May 19, 2003 8:12 PM
Hello Mark,
Regards Brian
Rgds,
To: ***@***.***
Hello Mark,
Regards Brian
- "Mark Spiers"
Hi Mark,
Yes, I'm in the U.K. having recently relocated from warmer climates
(Arno's neck of the woods..S.Africa) Don't worry about the camera,
God and the weather willing I hope to be at Castle Combe this weekend
(spectator only) and you can show me the "oddball" panal,looking
forward having a beer and agreeing to disagree.
my mobile is # 077420 48536
Regards Brian
Regards Brian
