CV Joints
Anyone tried the Demon Tweeks sort?
http://www.demon-tweeks.co.uk/catalogue ... EG1470-STD
Will they fit an Elan?
Works out about ?190 inc vat for the set. No bolts though.
Jeff 72+2
Subject: Re: [LotusElan.net] dont know if anyone is interested....donuts v CV
Chris Neil sells the donuts for L85 a pair. Could the VAT and postage
actually be as much as L45?
Frank Howard
'71 S4 SE
Minnesota
Jeff 72+2
Frank Howard
'71 S4 SE
Minnesota
jeff jackson - Fourth Gear
Guy's please ignore my last mail!!!
I was looking at Demon Tweeks "standard" do nut. The heavy duty type as used in our elans are ?151 each. For a set, that's ?714 inc VAT!!!
They have to be having a laugh. That's nearly Two Mick Miller CV setups.
Doh.
Jeff
----- Original Message -----
To: ***@***.***
Sent: Tuesday, August 24, 2004 9:00 PM
Jeff 72+2
Frank Howard
'71 S4 SE
Minnesota
Doh.
Jeff
To: ***@***.***
Jeff 72+2
Frank Howard
'71 S4 SE
Minnesota
So what are these;
RUBBER DRIVE COUPLINGS: ELAN AND +2 01MG017 ?49.50
Mike Geiger
--- In ***@***.***, "Jeff@t..." <jeff.taylor-
jackson@t...> wrote:
VAT!!!
Mike Geiger
VAT!!!
Mike Geiger
66 S3 Coupe', no more![Sad :-(](https://lotuselan.net/forums/images/smilies/icon_sad.gif)
type36lotus - Fourth Gear
Hello,
For the elan:
Overall diameter (assembled) 5.38"
Bolt center PCD (assembled) 3.78"
Dia of the fixing holes .45"
Width across metal faces 1.83"
Hole to hole span of shat flange 3.25"
Jacques
Elan s4/se
Sent: Tuesday, August 24, 2004 10:20 PM
CV
Look good but will they fit? Any know what the bolt circle for the Elan is?
***@***.***e:
=M008&CODE=PEG1470-HD&PGRP=MP113&GRP=MP113&PCODE=PEG1470-STD>
For the elan:
Jacques
Elan s4/se
CV
***@***.***e:
- lotuss4s
I Have the TT drive shafts .Solid construction ,grease nipples fitted ,easyto instsll ,can easily revert bact to original set up .Good take off no windup as with the rotaflex .
Down side, when the car is jacked up the knuckles bind and you cannot turn the wheels ,limiting straps could be fitted
Regards John 1969S4 DHC
To: Cheshirelotusownersgroup ; Lotuselan
Sent: Tuesday, August 24, 2004 12:13 PM
Subject: [LotusElan.net] dont know if anyone is interested....donuts v CV
But I have found a source for the rotoflex couplings.....?110 per pair
including postage and VAT in the UK
I reckon that it is a saving of about ?20 over what PM and CN charge and
as you may well need 4 of them then it'd be ?40 cheaper..mind you having
said that what was the cost of the CV conversion?????.....mick miller
was knocking them out at ?385 +vat..(did that include the +2 by the
way??)...so its back to the start of that argument again...CV conversion
or original donuts..8 donuts..?440..1 CV conversion kit ?450...it all
depends on how your donuts last...as it has been mentioned before they
just aren't made the same as they used to be...if they only last a
couple of years do you bite the bullet and get the CV.do you want
originality???....
As a famous man once said...." You never know before 'till after a bit
since "
Who has what CV conversion????.....there is mick millers version, tony
thompsons version, the ?lan factory from OZ (although this seems to be
very expensive especially when you stick the postage on!!!) and isn't
there also a spyder version...
Who has which version and what are the pro's and cons....what are the
verdicts?????
Gareth
Gareth Flanagan
Senior Technician
For Martin Stockley Associates Ltd
Riverside
4 Commercial Street
Manchester M15 4RQ
Tel: 0161 835 1122
Fax: 0161 833 1846
Email: <mailto:***@***.***>
Web: www.martinstockleyassociates.co.uk
Disclaimer Notice:
This E-mail and any attachments to it (this "E-mail") are intended only
for each party to whom they are addressed.
This E-mail may contain confidential information, the status of which is
not lost or waived by mis-transmission. Each unintended recipient should
delete all copies of this E-mail, destroy any hard copies and notify the
sender by E-mail or telephone, you must not use, disclose, distribute,
print or copy any part of it.
Martin Stockley Associates Ltd accepts no responsibility for: (i) these
drawing files following manipulation, amendment or variation of them by
recipient, and (ii) the use of these files by the recipient for any
purpose other than that intended in this issue.
Martin Stockley Associates Ltd shall not be liable for any loss or
damage (including consequential loss or damage) howsoever and whatsoever
caused arising directly or any: (i) corruption (including any
transportations of figures or measurements and errors) that occurs
indirectly as a result of to these files as a result of their
transmission to or use by the recipient; or (ii) virus contamination
that is caused by, contained in or transmitted by the use of these
files.
Riverside
4 Commercial Street
Manchester M15 4RQ
Tel: +44 (0) 161 835 1122
Fax: +44 (0) 161 833 1846
mailto:***@***.***>
originality???....
since "
verdicts?????
Gareth
Gareth Flanagan
Senior Technician
Riverside
4 Commercial Street
Manchester M15 4RQ
Tel: 0161 835 1122
Fax: 0161 833 1846
Disclaimer Notice:
files.
Riverside
4 Commercial Street
Manchester M15 4RQ
mailto:***@***.***>
Regards John 1969S4DHC
- triumphelan
Thanks - I have only just picked up your email. A conversion which includes
the drive shafts must be better. I guess you got yours in the States? Who
from and how much?
Ta,
David
-----Original Message-----
Sent: 21 August 2004 03:23
To: ***@***.***
Subject: RE: [LotusElan.net] CV Joints
David,
The CV-conversion kit I purchased from RDEnt requires replacement of the
inner stub axles. There is no inner adapter plate. The inner CV joint bolts
directly to the new inner stub axles (with the six bolts that hold the CV
joint together). The outer end still uses an aluminum adapter plate (with
steel inserts).
The new inner stub axles are very nice pieces; nice machining and very
stout. But, I am sure that the kit's cost is greater because the conversion
kit must include these expensive new stub axles, not just CV-joints, axles,
and adapters. If you are going to replace the standard stub axles anyway
(non-RDEnt systems), as David suggests is prudent, then the extra cost of
the RDEnt kit fades away.
One advantage of the RDEnt kit is that the intermediate axle shaft can be
slightly longer without an inner adapter plate. The longer axle would have
less anglular deflection at each CV joint for any given suspension
movement. I think this angular difference would be slight and probably not
a real benefit.
Rich Boyd
from and how much?
Ta,
David
To: ***@***.***
David,
steel inserts).
a real benefit.
Rich Boyd
- davidallen
David,
The name of the company where I bought my CV kit is RDEnt. Ray Psulkowski
is the proprietor of RD Enterprises. They are one of the long-time US Lotus
parts suppliers (a good bunch of people). RDEnt has been in Pennsylvania
since 1976.
The CV conversion that RDEnt sells costs US$1250. Seems very high at first.
If you factor in the cost of new inner axles (which are supplied with the
RDEnt kit, but would/should otherwise be purchased separately) the RDEnt
kit cost become more reasonable.
One negative aspect of the inner axles supplied with the RDEnt kit: the
flanges (on the inner axles) are unique to a CV joint (six bolt pattern),
they cannot be used with original Lotus equipment (donuts) or adapters that
require a Lotus 3-bolt pattern. The RDEnt supplied inner axles are very
high quality parts: stout and very well machined.
You can view the RDEnt CV kit near the bottom of a long parts web page:
http://www.rdent.com/pages/parts.html
or navigate through their main page:
http://www.rdent.com/index.html
I seriously considered the Elan Factory's CV kit. The kit itself looks
great. Their price was quite low (I have dated price info, so I won't
specify it here). The Elan Factory kit does not include new inner axles,
only adapter plates for your existing ones.
The Elan Factory sent me a Word.doc brochure of their kit (good photos). I
would be glad to forward that brochure file to you. The issue that stopped
me from purchasing their CV kit was the shipping cost. The Elan Factory is
in Melbourne, Australia. Shipping such heavy parts to the US, even on a
slow boat, would have raised the initially appealing price to a level that
made me start looking at other kits. But their kit was a serious contender
in my mind. Shipping cost is also a big issue with the UK suppliers; gasket
sets are one thing, axles are another.
Rich Boyd
since 1976.
Rich Boyd
richboyd - Third Gear
