Handbreak in Road Race S4
Most Elan racers I know back off the handbrake adjustment so the handbrake pads are well clear of the disc. As a result, the handbrake doesn’t work - therefore no need to reach it with a harness on.
Leave it in gear if on a slope…
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
What do you wish to use it for?
The FIA require standard rear caliper with the handbrake mechanism in place , with pads, rods and swivel. Cable?? , depends on who you listen to, but I've never heard anyone say the umbrella was required for the HTP.
Despite that, some have it ( as I do), but I'm not really sure why, it's only ballast. Mine is road registered and so should really have it,but..........
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
The only reason I need the handbreak is for starts on a hill at the startline!
Racing SMRC mostly at Knockhill
Could I have a hydraulic handbreak somewhere I can reach it intigrated to the origonal system? And leave the dash mounted one and cable in place?
Cheers Colin
Cheers Colin
- 4545colin
4545colin wrote:Hi,
Cheers Colin
Presumably there's a light system or a 5 second board, if you can't heel and toe it, a hold on the clutch for a couple of seconds seems in order???
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
4545colin wrote:Hi,
Cheers Colin
I rigged up a hydraulic handBRAKE on a Plus 2 I had, worked okay.
- Slowtus
Electric handbrake conversions are available for disabled drivers, so perhaps something like this could be made to work https://www.steeringdevelopments.co.uk/ ... -handbrake
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
Fit a line lock
https://www.competitionsupplies.com/bra ... line-locks
https://www.compbrake.com/product/brake ... cba1185463
Kindest regards
Alan Thomas
Alan Thomas
I thought you weren't supposed to use the hand/parking/emergency brake on a car after bringing the car back to the pits as it would cause the disc to distort? We use a "ye olde wooden block" on our Alfa race cars...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
