DCOE: Fuel Lines
Would love to see how folks are running their fuel lines to the dual 45s.
In process of running -6AN lines and would like to see what others have done.
Thanks in advance.
Thanks in advance.
- TWebb
TWebb wrote:Would love to see how folks are running their fuel lines to the dual 45s.
Thanks in advance.
Whatever you DO use - and in case you haven't looked at the Carbs and their associated lines and pipery - get the BEST and inspect visually AND using your olfactory organ because if and when they let go and depending on which Lotus you have, this can be the result.
Seriously, ignore at your potential peril...
- Slowtus
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
I used Earl's hoses throughout.
The push on hose weber connector is replaced by an AN- connector.
Mine is the light blue one.
I have many pictures of engine bays but most of the picture files are too big for straightforward uploading
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Graeme,
I have only used Earls in the past. Plan on doing so again with the Elan.
I don't see a fuel regulator. Is it hidden in this photo or somewhere other than in the engine compartment.
As to the throttle linkage is that a bespoke unit or is that something off the shelf?
- TWebb
The throttle linkage is a Sytec's one.
https://www.glencoeltd.co.uk/sytec-heri ... nkage-kit/
I preferred the routing to the TTR one.
It has been modified a fair bit. 3mm off the base plate , angled skim off the top corner ( to not foul the bonnet, and the pivot position has been changed to that it has more leverage so that the throttle cable travel to WOT is about 3/4 of what it would normally be.
The pressure regulator is in the boot, but the pressure sensor is at the carbs.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
661 wrote:The throttle linkage is a Sytec's one.
Hi Graeme
what sort of regulator is that with a remote pressure sensor?
Not the best pictures (show what you want if you can zoom in) The system is all goodridge parts, fittings, Hardline and 200 hose. The hardline runs from the boot along the original route and clipped to prevent rubbing, it terminates at a small bracket to the rear of the engine mount and then up to a T below and front of the no1 carb.
The pump is a Bendix Redtop and feeds the carbs via a Filter king regulator modified to accept the Goodridge 1/8" BSP -6 fittings. You may notice the fuel filler vent which I have fitted C/W roll over NRV valve. FIA like the cars to have a fuel cap that will not leak if inverted and has some form of lock, I wanted to retain the look of the cap so had to find another route for ventilation.
I hope this helps, good luck with your routing.
- TrevorJones
rgh0 wrote:661 wrote:The throttle linkage is a Sytec's one.
Hi Graeme
It's not automatic! It requires a manual twist of the knob.
You can see the regulator in the boot.
The sender in the engine bay is connected to a Stack pressure gauge
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Graeme,
Thank you for positing the pictures. Excellent quality work.
A question;
The argument for co-locating the pressure regulator with the carbs is twofold -
1. Under heavy flow conditions, there will be a pressure drop along the fuel line which the regulator can compensate for.
2. Under heavy braking or heavy acceleration, the 'column' of fuel in the pipe needs to be accelerated or decelerated leading to spikes and dips in fuel pressure - again having the regulator at the carbs allows this to be compensated for.
As you have a pressure monitor at the carbs, do you detect any of these effects when driving?
Andy.
A question;
Andy.
71 Elan Sprint (to be restored)
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Andy8421 wrote:Graeme,
A question;
Andy.
Yes!
It is noticeable. I have been running about 4.5psi static ( tried 4 psi, but lower pressures were occasionally noticeable) and I don't see drops below 3psi. ( where my gauge is set to warn me of low pressures) At Brands last week I had just put the engine back in and for some reason I noticed I was running 3psi before the race ( In the assembly area, so too late to change it) . I noticed quite a few momentary lower pressures during the race ( ie the gauge flashed red ). No power loss and I would guess ( my eyes were generally elsewhere) no reduction of pressure below about 2.5psi.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
661 wrote:Andy8421 wrote:Graeme,
A question;
Andy.
Yes!
the way I understand it is the carbs operate from a constant level in a bowl that is at atmospheric pressure : as long as that level is correct, the fuel line pressure (or even flow) would not matter imho. In order to obtain optimal carbs operation at all times, one does need to ensure that the bowl level is met at all time with minimal variations (ps. under heavy deceleration the fuel requirement is likely to be minimal - and most fuel regulators are of the "cut" type, they would not actively compensate flow by other means than re-opening the fuel tap, wihtout any fuel reserve to push back in, like an accusump would do for oil).
S4SE 36/8198
nmauduit - Coveted Fifth Gear
nmauduit wrote:661 wrote:Andy8421 wrote:Graeme,
A question;
Andy.
Yes!
That's my understanding too. It is interesting to see the pressures vary but they obviously keep the float chambers well supplied.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
what I meant is as long as the pressure does not go down to 0 for some time (to be defined) there should always be the proper fuel level in a well operating carb (i.e. you may set your warning to 1psi if it gets annoying)
S4SE 36/8198
