Final Drive
Depends on your cars weight and max revs, torque curve and tire diameters you run.
A friend with a S4 Seven runs 4.1 on longer tracks and 4.4 on shorter tracks and he has 190+ hp and uses over 9000 rpm and runs 175/60 x13 tyres
In my Elan I use 3.77 on all tracks and could probably benefit from using a 3.9 or 4.1 on the shorter tracks but I don't have the time to be swapping diffs. Despite my heavier Elan I use a lower numerical diff than my friend as I limit my 180+ HP engine to 8300 rpm but the better Elan Aerodynamics mean I have a similar top speed despite getting there more slowly than a Seven. I top out at 8300 rpm with the 3.77 diff down the main straights at 8300 rpm at long tracks such as Phillip Island with 175/60 x 13 tyres. On short tracks like Winton I am running in 2nd and 3rd gears all the time and not getting into 4th
Also big factor is what tyres size and type ie historic Dunlop , Avon, or modern low profile as they have the most direct effect on gearing.
I ran 26R with Dunlop CR65's 550x13's in period it ran with a 3.77 or 3.9, today I've got a 4.1 fitted and like Rohan at tight tracks (with ultra close 2.25 first gear) I use 2 and 3rd gears only on tight tracks. When its back on the track it will be with a 4.4.
Attached is a spreadsheet I update periodically with a tab for each new tyre that I find could suit my S2 26R. I have modelled using Ultra close 2.25:1 first gears and various final drive ratios.
V
V
- Vaughan
