Lotus wins Irish National Hillclimb Championship
After making the podium in 2nd and 3rd places over the last four years, I finally took 1st place in the Irish National Hillclimb Championship in the Historic Class 4, eventually beating last year's winner by 1 point on the last run of the last day of 13 days events, with up to 6 runs each day.
And drove the car to every event and drove home again
https://www.facebook.com/90118938007101 ... 41/?type=1
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Well done! Congratulations!
Well done Sean!
John Larkin.
John Larkin.
1967 S3SE FHC, 1974 Rover P6B, 1949 Lancia Aprilia
- John Larkin
Congratulations!!
Brett Engel
'67 Elan VR, '52 MGTD, '16 MX5 Club
Phoenix, AZ
Phoenix, AZ
- brettengelaz
Grand job Sean.
How?s the other +2 doing?
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
Is it a Zetec
- alan.barker
pcarew wrote:Foxie wrote:.....And drove the car to every event and drove home again
This is the best bit....Well done.
How modified a car is it?
Well Paul, I bought it out of a breaker's yard in 1985, and I've been improving it ever since.
It's still a fully road legal car, with all lights, electric windows, radio and heater, carpets and trim. We used to did a lot of touring, we did the MSAEuroclassic for 18 years http://www.msaclassics.co.uk/history/ms ... istory.php
Spyder chassis fitted a long time ago, Spyder adjustable wishbone fitted all round lately, as the original Lotus fixed settings were all over the place.
I recently built a new 1800 Lotus TC engine, using the new QED thick-wall 681F block, 82mm steel crank and rods. I am using Dave Bean low compression height pistons. I got caught out with these as the valve cut-outs were just not big enough for for the exhaust valves The engine turned freely by hand, ran for 3 events before dropping a valve which luckily immediately jammed in the port, causing minimal damage. All the exhaust valves were replaced, the heads were seen to be rubbing the side of the cut-outs.
The original head had to be replaced, as after numerous skims over 40 years the compression had gone to 11.8 and no amount of octane boost stopped it blowing gaskets. I'm using QED 450 cams and 45 Webers. It's remarkably tractable.
I dry-sumped it a few years ago for circuit racing, a small weight penalties for the hills no doubt.
I'm using an Alan Voigts 5-Speed T9 conversion gearbox, with the tall 1st gear.
Diff is standard Lotus 3.55 with Quaife ATB. Brakes (and so, bolt-on hubs) are Zetec (Sierra). Spyder made up special (CVJ) drive shafts to mate the original diff with the Zetec brakes.
Wheels are 14" bolt on Minilites on Yokohama Advan 048s
My secret weapon for next year is to fit the 4.55 diff, but I'll probably have to buy a trailer now.
