The body is off the chassis and in storage - major rust and deterioration of the chassis and components!
Plan is to replace all of the chassis, suspension and running gear, found a cosy (US) mouse nest with nuts in the front chassis turret!
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
So how on earth did you get the body up into the rafters ?
'72 Sprint
'72 Sprint
- richardcox_lotus
Thats the worst rust I've ever seen in an Elan chassis, it must have been a regular driver on heavily salted roads or sat on ground/in water hole for the backbone to be that far gone!!!
V
V
- vstibbard
The rust is worse than it looks in the pictures! Parts of the chassis have just gone - think it was standing rather than driven in this state.
The body is in the rafters with the help of 4 strong 18 year old lads!
David Rose
1965 S2
1966 S3
1965 S2
1966 S3
- dunclentdr
It's been a while since an update on my GTS project (have had to register under a new name too as problems with password etc).
Anyway, here are some pics of the 26R chassis and front end which is now largely done.
Engine is away and nearly complete, CR gearbox done and diff with LSD complete.
Believe it or not I have a project plan that will have in complete by March 2018 - bodywork and final assembly by a respected motorsport engineer. Will post more frequently now!!
It's going to be a S1 GTS by the way, French blue like the Shapecraft one in the picture.
David
David
- dunclentdr1
Nice work.
Whose front hubs have you used? They look to have a longer thread than the TTR ones.
Nice work.
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
S4 SE
S2 GTS
Peterson JPS Exige
661 - Fourth Gear
Hi Graeme
Thanks.
The hubs are from Kelvedon:-
http://www.kelsport.net/parts/product_d ... ctionID=46
David
Thanks.
David
- dunclentdr1
I' ve gone the TTR route.
Oddly I was speaking to Tony earlier today asking him if he would produce a longer hub for me such that it could accommodate a spinner locking wire. I suspect that it may prove difficult to persuade him but I'll sow the seeds.
I like the Kelvedon hub but I' m reluctant to start mixing my supplier when it comes to the important stuff.
Will you be at Malcolm's?
Graeme
Graeme
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
S4 SE
S2 GTS
Peterson JPS Exige
661 - Fourth Gear
I won't as have big party at home - are you building a similar car, perhaps we can compare notes?
David
David
- dunclentdr1
Hi David, those are similar hubs to the ones fitted on my Elan too.
In fact I lent Pat Thomas mine and he made this new version which is an improvement.
Looks great..
Gino Milano
Italy
Looks great..
Gino Milano
Italy
1965 Elan S2 Roadster
1965 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
1965 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
Hi Gino
Followed your build and found it very helpful, hope the car is going well.
Hubs look good, the Plus 2 calipers I have fitted at the front seem to extend further out than the flat face of the hub so hoping the (26r) wheels are going to fit OK!
David
David
- dunclentdr1
Hi David....the 26r wheels are the real look but when you weigh up the cost you can have two or three sets of minilites made up with the correct offset and incorporate the extra offset you need.
Re the larger callipers; you could fit some spacers ?
Gino
Gino
1965 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
1965 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
Hi Gino - you are right - they look the part, are very expensive and it would be nice to have more than 1 set - the minilites look great on your car too.
I have thought about getting a second set made up from this supplier, they will make to size/offset and also paint as required:-
http://www.imagewheels.co.uk/lm4-alloy-wheel/
David
David
- dunclentdr1
dunclentdr1 wrote:I won't as have big party at home - are you building a similar car, perhaps we can compare notes?
David
I'm building a race car, it probably won't be too dissimilar to what you are doing but obviously needs to be 'in period' for FIA accreditation. I have the +2 calipers on my road Elan. They work really well without MC changes. I;m afraid I don't know if the 26R wheels will fit but I see no reason why not. kelvedon do an alloy one. I don't consider it overpriced for what it is.
Whereabouts are you?
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
S4 SE
S2 GTS
Peterson JPS Exige
661 - Fourth Gear
