Elan Onboard Footage Snetterton
Some onboard footage from one of the 26R's we prepare from Snetterton last Friday. https://www.youtube.com/watch?v=qKdYqkLz2UI
- JohnDanbyRacing
Your engine sounds very strong. What is the build?
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus wrote:Your engine sounds very strong. What is the build?
Yes the engine is very strong! It is a fully FIA legal 1600cc engine. We had the car on the rolling road last week and it made nearly 170bhp at the wheels! We recently fitted a brand new engine block which has made a few more hp.
- JohnDanbyRacing
Any pictures of the engine bay? What Pistons and cams are you using?
Glen
mmmmm 170 hp at the back wheels ? I know how to get close to that at the back wheels in an 1600 cc S4 Seven where the exhaust routing is much better and the engine is not to FIA historic specs. But in an FIA legal 1600 cc engine in an Elan? I wish I knew. Also wish I was allowed your FIA minimum 580 kg in an Elan and that I weighed 60 kg also
How many hours engine life ? ....cant be many
If I saw that the first thing I would do is check the dyno calibration
rgh0 wrote:mmmmm 170 hp at the back wheels ? I know how to get close to that at the back wheels in an 1600 cc S4 Seven where the exhaust routing is much better and the engine is not to FIA historic specs. But in an FIA legal 1600 cc engine in an Elan? I wish I knew. Also wish I was allowed your FIA minimum 580 kg in an Elan and that I weighed 60 kg also
Hi Rohan,
Yes that's what I thought when we saw the figures, but we use the dyno a lot and we even had a car on it earlier in the day that produced within 2bhp of what it did on the engine dyno before it went in the car. Mileage wise we are doing 1200miles before a refresh, depends how hard you want to rev it to how long they last!
580kg is quite difficult to get down to, this car is 600kg with the large fuel tank. I also wish I weighed 60kg!!
- JohnDanbyRacing
jimj wrote:Isn`t that Stephen Bond`s car? Was Keith Fell driving?
Jim
Hi Jim, yes is indeed Stephen Bond's car, good spot! it was actually myself driving doing some setup work on behalf of Keith and Stephen. Keith drove in the swinging sixties race that weekend and finished 2nd behind a Camaro which was a great result.
Ross
- JohnDanbyRacing
PaulFinch wrote:Great footage.
The car looks quite stiff; what spring rates are you running, or is that a trade secret?!
What does the 1200 mile engine refresh consist of?
Hi Paul,
We actually went softer on the rear springs after that video as it was a bit nervous at the rear on the limit. We run 350lb on the front and 150lb on the rear. The stiffer front makes the car much more stable under heavy braking.
1200mile is a conservative figure so normally we just replace bottom end bearings and give the head a clean up and re-lap valves, check valve spring pressure etc.
- JohnDanbyRacing
JohnDanbyRacing wrote:rgh0 wrote:mmmmm 170 hp at the back wheels ? I know how to get close to that at the back wheels in an 1600 cc S4 Seven where the exhaust routing is much better and the engine is not to FIA historic specs. But in an FIA legal 1600 cc engine in an Elan? I wish I knew. Also wish I was allowed your FIA minimum 580 kg in an Elan and that I weighed 60 kg also
Hi Rohan,
I think you have just declared that your dyno is over-reading! Wot, no transmission losses?
I'm only 60 kg, can I drive it?
Meg
26/R with a grille and plenum chamber just in front of the windscreen?
Pete.
http://www.petetaylor.org.uk
Pete.
Hi Pete
Genuine car but with new shell from TTR. Not super lightweight shell hence the 600kg.
Most of the really competitive cars are at 580kg with all fluids and some even need ballast!!
Dave Hughes
Dave Hughes
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead - Third Gear
