2 litre oil catch tank
Any thoughts on the best current arrangement for the above (for an S2)?
TTR has an option that sits inside the n/s inner wing (so no brackets needed) but I already have a coolant return bottle located there (could be moved of course - I have a bracket)
Presumably I can use the existing crank case breather outlet to fit one connection to the tank, but have to drill the cam cover & fit an outlet there to feed the second connection to the tank?
Any help appreciated.
Dave M.
Dave M.
- Maulden7
This how I have done it on my Elan down to the TTR fibreglass catch tank that wedges in the LH triangular body section ahead of the foot well. I have recently concluded I need a larger bore connection to the head and breather pipe as the engine sump pressures itself up and blows oil out the front seal on the longer high speed circuits where I sit at max revs for long periods.
I don't use the original breather location as this is removed with the McCoy conversion heads
The normal breather vent is certainly adequate for a road car with an engine in good condition whether it is directed to a catch tank or to the air box. The only issue with the air box destination is that if the engine is worn and blowby is increasing you get more rapid plug fouling than normal because of the oil mist going back to the air box. Venting to a catch tank in these circumstances helps slow the plug fouling.
